Hi Nano
greetings any idea of core used in smps the round one with yellow tape and what core material please can you help out
warm regards
andrew
I try MMT140T5020
:: Magmattec - Tecnologia em Materiais Magnéticos
Nano.
If anyone wants to test the modified IRSK4.5 board(#2731) in the board-12x TO220
Warning board has not yet tested!
what about the component side?
pls post 3 pair 90n20 lay out file
greeting.
pls post 3 pair 90n20 layout file, thank you.
hi fra,component side is same as this only instead of 3 pairs irfp90n20 is 6 pairs mosfets in housing TO220
greeting.
Hi sir manojtm
what is the bias port on your AUD600 amp?
how can i brighe 2 of them?
can i use AUD600 amp with + - 30VDC and how much power can handel with this voltage?
sorry for my bad english
thanks
thanks
thanks to andrewlebon
Hi sir andrewlebom
please share every thing you have for new smps by detex
thanks
new smps by detex
Hi sir andrewlebom
thanks
hi andrew even fredos uses toroid core for his hi power D-amp over 7kwts
but in switching he uses igbt and not fets
guys please share a good and hi power smps that can be handel the class d amp
please do it for all peopel in this topic
thanks
good boy stewin
thanks
good boy stewin
Hi sir manojtm
thanks
sir manojtem
i am waiting for your answer sir
have nice time all off you
Hi Hadi,
ask about the 12v Bias point ??
you should assemble both PCB do not treat separate.
you can bridge my AMP AUD600 i will give you schema and wiring diagram
+30v -30v supply you will get 100W @4 Ohm load
for all DIY s
200V MOSFET like IRFP250N can handle max. +125v -125V supply with respect to GND and it will not survive short circuit and over current, it can handle only 8 Ohm load(tested OK). 200/1.414 -15 = 126 if it is wrong don't fire me!!!!!!
MANOJ
thanks to manoj
i mean balance not bias
sorry
how many voltage and curent for 300watt in 2 ohm load?
i will creat both of power and amp board
i have this and it is diferent with your last PDF file.
please help me to do that
sorry beacuse i am basic in electronic but i love it.
thanks friend
http://img4up.com/up2/21712604660202759918.jpg
Hi sir manojHi Hadi,
for all DIY s
MANOJ
sorry
thanks friend
Hi hadi,
for BAL INPUT + & - is input if you are connecting UN BAL mode + join to GND
for 300W @ 2 Ohm load you need +37V - 37V Supply @10A min.
MANOJ
MANOJ
thanks to manoj
thanks for your replay
what is this two point?
one is GND?
http://img4up.com/up2/79759157898187468456.jpg
thanks dear friendHi Hadi,
AUD600 schematic i will send to you soon pls wait
MANOJ
one is GND?
i do not underestand what are you say.Hi hadi,
MANOJ
please say it more clear
thanks
- Class D
- UCD 25 watts to 1200 watts using 2 mosfets
