UCD 25 watts to 1200 watts using 2 mosfets
component side is same as this only instead of 3 pairs irfp90n20 is 6 pairs mosfets in housing TO220
hi andrew even fredos uses toroid core for his hi power D-amp over 7kwts
but in switching he uses igbt and not fets
Hi sir manojtm
what is the bias port on your AUD600 amp?
how can i brighe 2 of them?
can i use AUD600 amp with + - 30VDC and how much power can handel with this voltage?
sorry for my bad english
thanks
sir manojtem
i am waiting for your answer sir
have nice time all off you
Hi Hadi,
ask about the 12v Bias point ??
you should assemble both PCB do not treat separate.
you can bridge my AMP AUD600 i will give you schema and wiring diagram
+30v -30v supply you will get 100W @4 Ohm load
for all DIY s
200V MOSFET like IRFP250N can handle max. +125v -125V supply with respect to GND and it will not survive short circuit and over current, it can handle only 8 Ohm load(tested OK). 200/1.414 -15 = 126 if it is wrong don't fire me!!!!!!
MANOJ
thanks to manoj
Hi Hadi,
for all DIY s
MANOJ
Hi sir manoj
i mean balance not bias
sorry
how many voltage and curent for 300watt in 2 ohm load?
i will creat both of power and amp board
i have this and it is diferent with your last PDF file.
please help me to do that
sorry beacuse i am basic in electronic but i love it.
thanks friend
http://img4up.com/up2/21712604660202759918.jpg
