UCD 25 watts to 1200 watts using 2 mosfets
150k is too low for full range audio
Yes.It´s slow , I´m working on.
It has gone up to 230KHz with other version and inductor cores.
I have the t106-2 core at 11uH , other core at30uH , other inductor 22uH .
The capacitor is at 1uF , other version it has 1.5uF
The smd version has 30uH inductor,1uF capacitor.
Now i got 45Watts at clippling limit at 20vdc with 5ohms load.
Vrms=14.8
R=5ohms
P= (V*V) / R
attachment.php
It starts to work when I turn up the volume , it looks like a kind of trigger level.
Any suggestion ??
There is a well known solution for this problem: it is needed to connect 30K-50K resistor between positive rail and inductor input (directly after mosfets).
The problem is that sometimes the input integrator wishes to start the oscillation with positive pulse, but the bootstrap capacitor for high side driver is not loaded yet. If we place the resistor between amp output and positive rail, then integrator will detect the positive error at startup and will start the oscillation with negative pulse, which will effectively charge the bootstrap capacitor.
I've been contemplating this build since it was posted, but I have one question (which might show my ignorance of this circuits operation). Is there a reason why the LM311 is powered by only +/-3V? Anything wrong with using a higher voltage?
The comparator has a finit slew rate. So higher votlage would need more time to change output stage.
Also the driven 2N5401 cannot take much higher voltage at its base.
I have one problem, my amp sometime starts beeping. I don´t know why. Can someone help me? 🙄
Where does the beep come from? from the speakor, or from the amp's component (like output inductor)?
Do you have two amp modules operating?
If you have two amps opereting there can be interference (mainly beacuese the two close carriers). Try plugging off the other amp module. If beep disappears then you should try to minimise interference. (filtering supply lines, ground connection redirection)
What is the swithcing freq of your supply and your amp modules?
Beep come from speaker. Yes I have two amps and when one plugging off then beep disappears. SMPS run at 75kHz and amp at 250Khz.
