Tube with Power IC Output Stage - JLTi
is my case shielded ? its made out of aluminium sides and top and bottom out of thin steel bought from one of the electronic chain stores here in oz. during this testing phase the top is off.
the chassis ground is made by a steel screw coming through the bottom steel plate and the connections Joe has labelled G chassis are connected to this point . From there another wire links the screw and its connections to the earth wire of the mains supply.
there is no resistor or cap anywhere in the grounding part of the circuit. The components of the circuit are as Joe described in his latest posts in this thread and the power supplies are as he describes on his website.
I should emphasise that its very faint this radio broadcast ,only just audible when the ear is inches from the speaker. When the music is on the broadcast is well drowned out. Its only the obsessive part of me that says I would like to get rid of it ,I assume it has an influence on the sound of music however faint.
from memory Greggc in a photo of his "ultimate gainclone" has a cap and resistor connecting the signal and ground terminal on his input RCA plugs to stop RF hash . This is the thread
Gregs is not a tube buffer though I assume that shouldnt make any difference. Thanks again
shoog
*My only mission now is how to reduce further that hum. Would a capacitance multiplier or a LM317/337 for the tube psu help on this hum reduction?
Indead my experience is that a capacitance multiplier can help to reduce hum. Mine went from been very quiet to absolutely quiet with the addition of a cap multiplier !
Shoog
Re: shoog
Shoog
This is actually what I did in my next VBIGC project. The last one I built sounded great, I hope I can make this one better.
PSU boards for tube, heater, GC amp.
JojoD818 said:
Hi!,
I tested a valve buffered gc as per Joe's schematic. I connected a load, but without any signal. When I turn the pot clockwise, the speaker moves in and when I turn the pot counterclockwise, the speaker moves out.
When I connect an input (cd player), the amp works fine, but when I turn the pot, the same weird thing happens.
Any suggestions would be very helpful. Thanks.
JojoD
This weird thing happened again on my other VBIGC project. I measured my heater voltage at 6.4VDC near the filament. It plays but when I adjust the volume pot clockwise, the speaker moves out and vice-versa.
I have rechecked my wirings and no fault found.
I removed the pot, then I measured from the 3.9K resistor (other end is connected to the grid of the tube) to ground and got a reading of -14.5VDC. Is this correct? Must I have such a DC voltage at my input? When I reconnect my pot, the voltage disappears. I tried inserting a small 0.22 capacitor between the pot and the 3.9K resistor and my problems were solved.
What went wrong? Any ideas?
JojoD
6,4V is OK, little bit too high for my taste.
Check your source for DC offset.
.....I removed the pot, then I measured from the 3.9K resistor (other end is connected to the grid of the tube) to ground and got a reading of -14.5VDC.....
Grid must be allways pulled down to ground with a resistor. (DC bias set, resistor can be high ohmic like 470k, 1M). Your measurements method is faulty.
I just did what you told me (put a 1M resistor) but I leave the 0.22 cap on. The tube output is fine now, only 0.4mV and does not react with the movement of my pot.
I hope there is an explanation for this. I have built this circuit many times, last problem was caused by too low heater voltage but I have checked everything in the circuit I do now, and everything is where they should be. 😕
JojoD
I would like to ask what is the purpose of the 1M resistor and 0.1uf cap from the non-inverting pin to ground?
I have seen other IGC circuits but they just have the non-inverting pin connected directly to ground.
I also noticed that building the circuit without the tube (just the IGC) still produced a turn-on thump:smash: .
I have tried NIGC and they are dead quiet at on and off. How home the IGC has a turn-on thump?
JojoD
