I do remember something, change out the screen resistors for something more reliable. 🙂
Check current measurement resistors in cathode circuit and probably replace them too.
I don't remember having problems with leaky coupling caps, but the amps were not old at the time.
I saw a number of these amplifiers and the JA-80 (and larger) - even new they were not always reliable and were (are) sensitive to output tube quality.
Amp
Thx
I only set it to 2 until I find out if it blows tubes.
M
2V is way too low, you will definitely get crossover distortion. The Jadis value is actually quite low already, I would set to 4.5V and leave it be.
Thx
M
Amp
Mine has fuses. I will follow your advice. I have Svetlana 6550c in there, of which one went black and rainbow, and why I started this thread. I put an Electro Harmonics KT88 to try. In row with other two 6550c it draws half the current in circuit biased for 6550
While it has been 20+ years since I serviced one (as you know), each tube has an individual bias resistor and if you reduce them to reasonable values for the 6550, the driver stage will not be able to drive the output stage properly.
Some of these amplifiers had fuses in the cathode circuit, presumably yours doesn't.
Whatever charm these amplifiers have is in the funky circuit design and output transformers, I would not modify them other than perhaps to reduce the raw AC supply to no more than 117 using a buck transformer.
I would make a jig to measure grid current and check each tube under the existing operating conditions for grid current. Select those with lowest grid current for use in the amplifier. (Get some extras)
FWIW most modern KT88 use the same internal structures as modern 6550 (there are probably exceptions) and there really isn't a large difference between them unlike MO KT88 and a GE 6550 4 - 5 decades ago..
The SV6550C if you can find NOS are probably about as good as you are going to find for these amps now.
Dude, that tube, all the tubes and the amp look psychotic.
I don't think you could find tougher tubes. Or find someone to put the cathode as a top cap.
Buck transformer
Hi
I’m not familiar with “buck transformer”. Found some online/ebay but not sure which one to get or how it works. I wonder if I could increase the 4.7 ohm resistor between reservoir caps and smoothing caps to drop the voltage. When I got the amp that resistor was MISSING completely. Someone just soldered smoothing caps to the same diode that supplies the reservour caps. Amazing.
Hi
Amp
Yes, one tube went bad and previous owner threw in a used chinese KT88. He gave me a spare Svetlana 6550C, identical to the rest, which for some reason he did NOT install, but used that KT88. I pulled out the JT88 and put the 6550 in (tested nearly new on my BK747). It promptly went black and blue. I measured the bias on the KT88: when it is installed as a third tube in s triplet (Defy 7 pot supplies bias to each row of three), chinese KT88 draws 1/3 current of 6550. Russian KT88 draws 1/2 of current of 6550. They are barely working in the circuit, guaranteeing they will not run away, overhead or blow-up. I have to examine that #1 position carefully, actually all in that row. Perhaps there is a bad connection or another problem on #2 or #3, which sends all current to #1. Stupid design, if you ask me. If it fries a newly bought tube in that same spot again - ciao, Defy. I will sell it as is, and right-off my loss as experience...
With respect to the other posters, I think it is premature to suggest modifying the amplifier, or replacing parts, without some concrete evidence of what is wrong. For one thing, modifications will ruin the value of an expensive audiophile amp. I could say sell it and buy an ARC, but that is also a useless response 🙂
If this is a defy 7, the schematic says the cathode of each output tube is fused with a 160mA fuse. Make sure these fuses are installed and are the correct value. If so, they will prevent chernobyl of the the output stage regardless of what happens.
I think the best course here is to put in the new tube, set bias, and just use it for a while under observation. If all is well after a few days, keep using it and the eventually buy some matched tubes once you are absolutely satisfied it is reliable and have saved the money for them (or maybe never?).
Another thing to check is bad solders on the board. I don't say to touch it up if it is good, just inspect all the solder around the suspect tube for cracks or cold/dry joints, and fix if required. This step is optional but may make you sleep better at night.
Yes you can use radio Shack contact cleaner, just a little bit in each hole, and then insert and withdraw the tube a few times, and wipe away the excess (if any) from around the socket with a rag.
The evidence here tells me that one tube went bad, so the owner threw in a used KT88 which was close enough, and got on with life. This gives me the impression that nothing significant is wrong with the amp.
The tubes just need to be burned in and closely matched, and all of those resistors good. I've always regarded these amps with something akin to morbid curiosity. I remember repairing some JA-80s and putting KT90s in them which were a bit more rugged than the then available KT88, and delivering them to the customer. I heard nothing more for 10 years or so, and ran into the owner at some audio meet who informed me that they had worked fine over all of those years. <relief> 😛
Amp
Thank you
Well, this certainly gives me hope. Did you only repair those amps? With no mods? May be I should buy some KT90. Even though tubes in this one are very closely spaced, big bottles may have rough time.
Thank you
Just a shot in the dark. Is it making a protest for diversity?
The sockets are these:
PLE08-0 Omron Automation and Safety | Relays | DigiKey
Those are -plastic- relay sockets!! They are not rated for the high temps tubes produce. And someone already mentioned that that position gets poor air circulation. You would do well to change all the sockets to ceramic ones. The plastic may be near semi-conducting by now.
It's hard to tell by the picture, but I thought they were Bakelite.
PL08 Omron Automation and Safety | Relays | DigiKey
I think you are correct. But surprisingly these sockets survive in Jadis amps for 20 ys
Sockets
They are Bakelite. The relays they are designed to work with sometimes carry a lot of current.
Then they are fine. I have Bakelite sockets that are still fine after 70 years in some equipment.
i valued the "cinch" sockets, i get them used, but they are way better than modern ceramic stuffs from china, those ceramic sockets break the center guide pin on octals...
Hey Tony. Ever use these? 20pc 8pin Bakelite vacuum tube socket octal for Chassis EL34 KT88 6550 6SN7 amps | eBay
I use these when I build with octal. The ground tabs are very handy 🙂 Never had any of them loosen up.
i prefer to use those cinch sockets that were pulled out from surplus military gears.....very reliable, with ground tabs too...
New tube update
Hi all
So the new Svetlana 6550C that I was waiting for finally arrived today. Aaaaand... it’s a totally different tube. My old tubes are all serial numbers 96XX, which places them in 1996 production year. This one is 18XX so it was produced in 2018. Type is silver not gold, bottle is larger and taller, getters Fire directly up instead of 45 degree angle like mine, and the worse part - while mine are let’s say at 1v bias (between ground and fuse, Jadis instructions, I’m bringing it up on Variac), this one gets to only 150mV. Another words it will require a lot more voltage to get it to proper bias current. Even my Electro Harmonics KT88 was getting to half voltage of the old 6550s. What is going on? Did they change the tube this much??? I’m sending it back.
Hi all
The only Cinch sockets I have are the 9 pin wafer type. Quite marde...
i like marde.....😀
i used a lot of those wafer type 9 pin sockets and never regretted....no bak jobs, with china ceramics, a lot of pain....
- Tubes / Valves
- Tube turned black and rainbow. Cause?
