when i will install those small transistors i will do it from the top of course so thats why i ask for this, so i can know exact c b and e places where legs go.
Okay, with your meter ...
You will measure a diode drop from the base to each emitter and collector. The polarity depends on the part being NPN or PNP. The base is positive on NPN. hFE test, one way (swapping emitter and collector) the beta will be much lower than the other. When you have the high beta reading, that is correct.
There was a little drawing I made from the pinout of each transistor.
I guess you found that.
Look at that, one transistor at a time an find the holes on the board that correspond with E B C.
First there's the small black one, then two BD139 and one BD140.
Try, I'm sure you'll find out, it's really not that hard.
Hugo
Hugo
Post a picture of that little note that came with the parts so others can follow.
Now, have a look at it and compare to your markings.
What do you see?
Hugo
What do you see?
Hugo
thats ok but i cant do it 100% there are no markings of any kind on old transistors so i cant really do it. i am sorry but i just cant, this is what i assumed it was like and that was all i can do
Don't think of the old transistors anymore.
Follow my paper to find B C E
I marked B C E on the lower part of the picture for all four transistors.
Hope this helps.
Hope this helps.
- transistor amp not working after shorting output
