Either works down to 4 ohms. If you mod it for PBTL mono it can handle 2 ohms.
yes, it can.
you will not get the full power, but the sound quality is great.
It works great as a preamp with ability to drive 2 volts - enough to clip most amplifiers.
Be aware that max output of minidsp 2x4 unbalanced is 0.9V.
You should check what is the input sentivity of TPA to make sure you can fully drive it.
Digital volume control is Great as long as you keep the pot above 12 o'clock, thats because with digital attenuation you are loosing bits - resolution.
It seems that the YJ blue board is now on aliexpress.
NEW Class D amplifier board TPA3116 2.1 channel 2X50W AMP free shipping-in Consumer Electronics on Aliexpress.com
The description is wrong, and the seller has zero feedback so far.
With the 26dB gain on the 3116, I can definitely drive my 91 dB efficient speakers to loud, almost un-tolerable levels of volume with a 19 volt smps. More than enough oomph IMO. I have not had an issue with low resolution volume control due to bit loss of the volume knob ADC.Be aware that max output of minidsp 2x4 unbalanced is 0.9V.
i saw that today.
15,xx € shipped to germany.
i do not need it, but the price is hot.
Thumps up.
question for X, apologies if this comes across as a PITA,
but the link in post 2273 sez gain is set at 36 dB,
was this a typo on their part or did you replace a couple resistors to get 26 dB gain?
Also curious whether PLIMIT has been set on these boards,
the illustration on p16 of the TPA3116 datasheet makes it look like a fairly hard clip
when it's activated, and my presumption was that a lower gain setting
might leave enough headroom to simply avoid that possibility.
Any thoughts/experience regarding this greatly appreciated in advance,
Quard
Quard
I guess I lucked out, mine actually shipped with 26 dB gain despite what the specs say. It also has a blue PCB and not green. I looked at the two gain resistors and indeed they are 20k and 100k per Table 1 in the TI spec sheet. It also sounds the same loudness as my previous homebuilt TPA3116 which is what I was referring to when I said the miniDSP can drive my speakers to near intolerable levels.
Sorry this is all so new to me. The YJ with tone control is listed as having a max output of 2A. That's much less then any of the other 3116 boards I have been looking at. Is that something I should be concerned about or can you shed any light on why it's different?
TPA3116D Tone Adjustable 50W 50W Class D Completed Amplifier Board | eBay
I am in need of an amp that has tone controls for a portable B652 set up I'm working on.
Thanks, Mike
Thanks, Mike
![T2oIw5XmNXXXXXXXXX_!!90439224-800x800_0.jpg](https://www.yuan-jing.com/image/cache/data/PowerAmp/Stereo/TPA3116D/T2oIw5XmNXXXXXXXXX_!!90439224-800x800_0.jpg)
You mean the words "TPA3116D 2.0 AMP" silkscreened on pcb? 2.0 amp means it is 2 channel stereo AMPlifier. with sub is 2.1.
YES! PS high freq SM caps as close to chip as possible! Even under the heatsink!
Any other place to get these?
TPA3116Êý×ÖС¹¦·Å°å12V ´ó¹¦ÂʳÉÆ·°å/´ø¿ª¹ØµçλÆ÷/²¢½Óµ¥ÉùµÀ-ÌÔ±¦Íø
I search Aliexpress and could not find this one on sale. I did not search EBay but I doubt it is available there. Taobao is the only place where it is being sold now. I guess you have to use one of those TB agents. I am thinking of getting this one too.
I bought mine here: Wholesale Product Snapshot Product name is Free Shipping! 1pc TPA3116 Class D digital amplifier 50W +50 W with Silent Sleep Design
But unless you are prepared for 2 month wait, not advised. It is a very good price for the quality of the board though. No problems so far, the inductors seem good as they do not even run warm at all. Great heatsinks too.
I recently shipped something to China with first class mail and it cost more than this amp (free shipping). So you have to take it for what it is...
Edit: oops, I see you were talking about different amp...
xrk,
Agreed. This is excellent price!!
I don't think so.
The hotlink isn't working but if you search 161104063365 on ebay it will pull up the board.
In the description:
Work: D Class
Quiescent Current: 65mA
Efficiency: 90%
Rated output power: 2 * 50W
Frequency response: 20Hz to 20KHz
Working voltage: DC18V to DC24V
Maximum output current: 2A
PCB size: 70 * 105MM
Potentiometer functions (from left to right): Volume Bass Treble
In the description:
Work: D Class
Efficiency: 90%
The YJ blue board is also available from Hiamplifier's store at EBay. Price plus shipping is almost the same. Shipping from Hong Kong is usually faster as compare shipping from China.
I don't think so.
In the description:
Work: D Class
Efficiency: 90%
That is just wrong unless they are basing it on the max rating of their inductor - go with the specs on TI's spec sheet. With a 24 v supply and 4 ohm speakers, and assuming you can drive up to say 0.8x of supply voltage that gives almost 5 amps. Assuming you have a 5 amp capable power supply.
If you want to drive the Dayton B652's you have more than enough power with this amp.
Yep I was talking about that new Taobao one. But for the price you got yours, I might buy this one too! So you had to wait 2 months? I will not buy from sellers with 0 feedback, I guess this seller is alright since you got your board despite the long wait? This version seems well done as well with the removable green plugs and smd components, seems neat and tidy.
Let me know how it goes and I'll follow suit, want the 2.1 taobao version. I'll also likely go with the green 2.0 one xrk linked for 14 bucks, thats a great deal.
I have. It works great.Who has run the blue board strictly off a volume pot??
- Class D
- TPA3116D2 Amp
