TPA3116D2 Amp
I just got it a few days ago and have been rather busy getting my 200 watt $20 IRS2092 to work. Just got that finished last night with a proper Abltec 53v dual rail supply. Oh there is so much headroom with a big amp! It is very low distortion. Anyhow, back on topic. I have not had a chance to listen to it. It does look quite different visually and now StanleyB is pointing out all sorts of strange crossed vs star wiring on the bypass caps. I am actually not following this line at all? Aren't the traces from the two bypass caps to the Vcc pins so short, it doesn't matter if it is star, ring, or crossed?
Thank you for the reply. I briefly looked at the component lay out of this blue/black before buying and it was very similar to the YJ. So I assumed the PCB was the "same". But when I hooked it up. It was disappointing, I rank it even lower than the original YJ red 3116. Well, these things happen.
Glad to hear that the"big amp" worked out well. I am waiting for my 7498 to arrive.
Regards,
http://www.hypex.nl/docs/papers/The%20G%20Word.pdf
You like to read🙂 Same die poweramp as 3118/16 in tas chip, TI has no 1nF's on pcb.
I see. I'll keep the 1nf for now, albeit different place, as I bought after trawling few many spec sheets to find just the right ones. Just need to check spares tin to see if I got some 10nf to try underneath for now, as I got to get some 10nf anyway for elsewhere.
And yes, :shhh: I like to read. Read lots on various subjects including audio mods, tweaks, manufacturing differences etc as well as vast quantities of spec sheets and d-class stuff lately. Don't get out much, prefer music!!! 😀
For listening to music YJblue is bad choice. For practising soldering skills it is best on market 🙂
Mildly comatose amplifier theory 😀
Do we run long wires from the decoupling​
capacitor to the star and add​
exactly as much inductance as we were hoping to get rid of?
With a star you can just about build a mildly comatose
class A amplifier. Anything faster and you’ll run​
into stability problems. Try switching circuits and​
all assumptions go out the window.
I totally understand where your coming from. If I had the choice I'd prefer to do my own design PCB, but done that for half my WiFi DAC and it proved very time consuming and expensive compared to $9 amp + a few more for changing components!.
Pretty sure these will sing with some work.
Got rid of 10nf last night and moved the 1nf in its place to match other side. Sounds fine.
Left the two pads from the original 1nf exposed without cap.
Question..... Any recommendations of product for covering exposed parts of PCB?
At the same time I shortened both 1nf legs to absolute minimum...that was tricky to reattach! And in process one of the pads lifted. Luckily, for now anyhow, the other leg soldered holds cap and pad in place firmly.
What are your solution for multiple inputs? I have an old turntable that i want to use but i only have one input channel on my amp, so is there some sort of a splitter
For your turntable, you will need a phono preamp. For multiple inputs, I made an input selector switch box:
Sorry to bother, I ask again.
Perhaps it is my fault, I tried to read as much pages of this thread as I could but I did not find if someone tried to configure Ybdz "Weiner" green or blue board into PBTL and if it is therefore possible.
In the positive case, if filter values (inductor ans resistance) should be changed.
I would also ask if something else should be changed in the case one would like to use it for a 4 ohm load.
Anyone?
Anyone?
I haven't tried but no reason it shouldn't work like other 3116 ampboards. Connect chippin 9/10/11 together. (Boards that come with prefab pbtl option also connect outputsignal both + and - for right (and also for left) together at bootstrap capacitors). And right speaker outputs + and - together become +, left outputs together become -. Unchanged filter all 4 outputs used will be for 4 ohm load.
Head scratching time. Removed the SMD .22's, checked them they are ok. Changed them for .22 Wima's (63v) fired it up.......same problem. Any ideas?
Here is a pic, I am sure that everything is in the right place.....but some other eyes might tell me differently.
Those are new resistors that started to smoke as soon as I turned it on.
