TPA3116D2 Amp
Alright, I have received my green audiobah board
You know when you have big expectations on something and then when the product arrives your expectations are not meet ?
Not the case here . The board is well assembled on a high quality pcb.
Bad news for modders that don't own a L/C meter is that there are no big or fancy capacitors introducing parasitic inductance and pretty much everything is SMD. The good news for the rest of us is that this board is 100% turn on / off pop noise free , the hiss is much lower in level than the red yuangjing board the sound is overall better and you can also get on 1x100W mono by just soldering bridges.
Now, I am really enjoying the song coming from the tpa3116 as everything is there and sounds just right.
I am really glad to read your positive comments on the boards🙂. I have two of these sitting in my brother's place waiting to be shipped to me.
Regards,
Personal reviewed this board have below comments:
1) Wrong inductor in used, this is common mode choke use to block higher-frequency application and low Q-factor. Lack of HF presentation.
2) Four mount holes are un-isolated grounding. Have the grounding problem must pay attention for metal box installation.
3) Two pieces of ECaps is cheapest for general DC application.
4) Modder without any chances to mod or Sync connection.
Have you try the YJ blue board ?
As a modder with an L/C meter I still see 2 large capacitors introducing parasitic inductance 😉
You can't really put the parasitic inductance that you have onboard with all around trough hole component's like the YJ blue against a all around smd like the green board or the YJ red board .
I would not know what having an L/C meter has to do with ready made designs ?!
If you want to sort things out or even set the output filters to match your speakers a L/C meter is needed when you have a board full of smd components.
True, SMD is fine at most spots but does that also count for the input caps and for the output filter ? Did you also try the YJ blue board ?
I agree with you as I like to have big coupling caps and also some polypropylene for the output filters BUT I appreciate the tiny size and quiet background of smd. If someone could pull out a TPA3116 board using trough hole for coupling caps, bootstrap caps, and output filter components ONLY on a properly designed board I would definitely go for it.
My complains with the YJ red board wer the lack of bass, turn on / off pop and the big amount of hiss. I see already too many people having the same issues with the new, YJ blue ( or black ) board while the green board, stock form has nothing of that. I sure will change a few things here and there but in stock form the green board is miles ahead of the red board. In a few days I will see how good the YJ blue board is.
Who's said the black board has hiss, bass problems? I have experienced neither.
It sounds good even with these. You know it is very hard to find a Class D board with inductors that are "OK". I have already changed to some t68-2 iron powder cores wound to 22uH .
Nothing is perfect 😱
Sorry ?
They have not been delivered yet. What about you answering to my PMs ? I want to have a go at your board !
Hiamplifier,
I am interested in your board and I sent you an email (via your EBay store) inquiring about your new board. You did not even bother to reply.
Regards,
I have just received one of the green boards. It has a connector with three pins labelled SD, MUTE, GND corresponding to the same pins on the chip.
Am I right in thinking that I should short SD and MUTE to mute the amp and SD and GND to switch it off?
The datasheet is less than crystal clear on this.
TIA
giulio
A few pages ago there was a couple of guys complaining about it.
Do you have pop at turn on / off with your YJ blue board ?
The hiss/plop comes from an "open" amp with no source being connected/powered. IMO just 2 resistors would solve that. If a volume potentiometer is used this problem won't occur.
Sorry but you are talking the blue YJ board bad and the green board good. Just from the looks and theory ! Those parasitic inductances and capacitance are not always detrimental. I would rather have film caps for the inputs than SMD ceramic ones as they simply sound better. If it is right that the output coils are common mode types .....
*the uninsulated mounting holes are very interesting. I have seen quite some amps from China that have that. Just think what will happen if you use such an amp with an open frame SMPS (case always connected to PE) in one metal case.*
Finally turned on my YJ 2.0 blue boards and do have hiss emitting from the speakers, plus the on/off pop is present... note, this is without any form of input source connected & with 100K Ohm resistors fitted between L/R inputs to GND.
With a basic volume pot added to the input [still without a powered source], at full volume hiss/pop still present... reduce the volume, hiss/pop reduces but is still present... Connected to my miniSharc set-up, things improved greatly with only a slight audible pop on power off.
Not listened to any music with these yet, just made sure they turned on/off ok with no issues. Will probably get a miniDSP 2x4 to use specifically with the two YJ 2.0 blue boards.
Paul
