Today's Version of The Williamson Amp
The only reason choke-input supplies were ever used in the first place was because cheap, small, high-capacity electrolytics didn't exist.
The key word there is "cheap". Again, that is the sole reason cap input supplies came to dominate. From a technical standpoint they are horrible. Crappy power factor, poor transformer utilization, worse regulation, much more harmonics and noise.......
They are about as relevant to hi-fi as vacuum tubes themselves. 😉
If you don't think tubes are hi-fi, then why get involved in a discussion in a tube amp forum 😕
Sy, this is the article that I found a few weeks ago.
Yes, I've seen that. I think we can do better. 😀
Indeed. The article contains inaccuracies such as "The mains hum and the 3rd harmonic distortion component are in phase in the valves and consequently cancelled in the output transformer." Ehh, 3rd harmonic? No. And mains hum (dont forget noise from the crappy cap input filter) is never perfectly cancelled at the quiescent operating point. Furthermore, it becomes worse as the tubes operate over a cycle, with their respective gm constantly changing. PSRR is at it's worst when one side of an AB pair cuts off. Fortunately a good power supply solves these problems. Unfortunately, the author of that article recommends the worst possible power supply configuration.
marl0w3
Please specify which is the value of R18 or the correct bias for this schematic.
Thx,
M
Hi M
I found about 600 ohms with the 6n6 i have, but depends on the tube you could fit a 1k pot.
i have found with just about any tube 12BH7 and more, an adjustable pot is best if you want the phase splitter to work correctly.
sorry: When i scanned the circuit for this amp i put the wrong power supply.
Phil
ANYbody ever build the "Mono Bill" classic? Is there a wesite for the amp? It looks like an old Heathkit schematic. Consider using Edcor or Hammond transformers that are easy to obtain.This is a great project...or at least could be if the pro's help out....
power supply improvements
I did like the amplifier part described by Byrith and was contemplating building one...
What would be a good approach to a 'best possible' power supply for an amplifier like that. When I want good PSRR that typically involves active components - dare I say semiconductors. What do you suggest to keep with the spirit of the valve amp?
Something else that probably needs improving is that the HV kicks in before the valves have time to heat up. Other than using valve rectifiers (with the associated problems), are delay circuits used or is that again against the grain of things? Guitar amps just use a standby switch but that is not common in audio amps...
