Three-pole compensated blameless clone
it will be clear when you look at the dac -> adc graph
Measurement : unbalanced 24bit 96k
DAC Topping D10s
ADC X-Fi HD USB
DAC -> FukAMP -> voltage_divider -> ADC
DAC output -13.5dBFS
ADC input -6dBFS
DAC -> ADC
DAC output -17.5dBFS
ADC input -6dBFS
Noise measurements
Cosmos ADC unbalanced noise (input 50R) = 2.111uV or -113.5dBV
FukAMPv4 voltage amplification = 35.9x or 31.2dB
Simulated noise bw 20kHz = 26uV or -91.7dBV (ideal power supply)
Measured noise bw 20kHz (input 50R) = 29.8uV or -90.5dBV (SSR3 included)
Square wave test.
4Vpp 10kHz, load 2R parallel 47n,100n,680n,2u2.
Measured after the output coil. (just 0.1uH)
Fantastic, completely tamed 3 pole TMC compensated VFA at 3MHz ULGF.
Reactions: 1 user
Personally, I don't care if the amplifier has a distortion of 0.001% or 0.00008%, the sound performance is more important. I would also buy Fukamp boards, but there are 3 things that bother me.
1, Absence of quality polypropylene at the input
2, Wago terminal at the output, into which you can put a maximum of 1.5mm2, even with problems, ... (I prefer Faston)
3, Missing choke at the output, which you replace with a 30cm wire... :smash:
