Three-pole compensated blameless clone
I made a measurement amplifier to extend the voltage drive capability of the Viktor oscillator. Yes, it uses triple pole compensation.
THD1k measurements.
The chain was : Viktor1k -> MAmp -> low impedance voltage divider -> passive notch filter -> post notch amp +40dB -> modded X-Fi USB HD
Guys, are these measurements ok ?
sine 1k,10,20k clipping into 4R
sqr10k 40Vpp into 4R
  • Thank You
Reactions: 3 users
I'm still just at the beginning of tuning.
The first THD measurements give quite good numbers.
THD1k 10Vrms,20Vrms without load 0.00001%, into 4R 0.00006%
Three-pole compensation works, I tried TMC and TPC (jumper on pcb)
Reactions: 5 users
The third version is assembled. The very first measurement showed excellent distortion performance, comparable to a "wolverine" amp. CCIF IMD 50W/4R 0.0002% (I think it was limited by my equipment)
Reactions: 5 users
The fourth version of the PCB is ready. Version 4.1 is on the way (I've been waiting for customs clearance for 20 days now) and will be sold to local diyers.
SSR3 is also part of the measurement - THD 1kHz 50W 4R . Classic output coil is not used, despite this, the amplifier is stable to capacitive load.
Reactions: 2 users
