This is the DHR.... Dx High Resolution Turbo
Not needed..do not post class D here...the thread is for the High Resolution Turbo
Postings about class D will be considered off topic by the forum management, and by myself,..because it will be really very off topic!... this is DHR Turbo thread and this forum is Solid State...will be entirelly and absolutelly off topic and wrong to have those things published here... you may be novice into the forum.... this is a rule we try to obbey..as this avoid mess.
Yes..we can make small and fast comments..but not start discussions and post schematics about off topic things.
Thank you anyway, but decline to have some help...i already have the schematic, the idea, and a circuit assembled to tweak and finish..and i cannot publish, explain how operate, publish or give the schematic.
I prefer not to "polute" my mind with other folks ideas... i cannot use them..i have to avoid them..mine must be different, original and revoluctionary.
Not needed suggestions or schematics.
I need time and motivation to go on into such kind of job..i dislike integrated circuits and i am using those damn things... black boxes... i have no control related what have inside the case..i do not like that sittuation.... into solid state we have entire control... about chips we have to accept what is inside.... grrrrrrr!
Nothing really needed!..i have all the parts, the tools, the knowledge and the schematic created, calculated and half tested..things already decided....suggestions will not change my circuit as i will refuse everyone to make something different.
I need motivation.... to move!.... as i told..i do not appreciate integrated circuits.
Also i have Class D using only discrete, do not send me schematic for that.... i will do the one i have... will not make any suggested schematic...have to be mine because will be a business and i cannot copy or use suggestions on that.
Thank you anyway......no one can motivate me..this is some job to be done internally on myself.... i have to motivate myself to watch the chip assembled and not to feel bad.
Carlos
Well...our new forum face is nice
I am just testing to see the attachment maximum size.
Image size now is fine..not needed anymore to upload to imageshack i think...now i am trying to find the way to see my avatar appearing..it seems forum is already managing to do that for us.
regards,
Carlos
No, i cannot do that by myself...boards were not made by me..try with Alexmm
If he want to provide those gerbers i have anything against that...i do agree in advance.
But, please, keep the board as original...or...keep the one published as standard, avoid to publish your modifications, your customized board, to avoid too much versions around the same amplifier.
I have not those gerber files...i have, alike everybody, the pdf layout only and some pictures from the board populated..and also the pdf schematic..this is all i have, and all that stuff was published in this same thread.
Why that?... why i ask people to avoid too many options.
When people see too much options, too many models, they feel confused and give up to build.... as we are DIYers, the idea is not only to produce ideas and boards, but to build them as a real final product..better than virtual we gonna have something real, something that really plays sound and music.... too many options, as i could see and realise, results a problem.
If you decide to show your work (good), and to publish, then please, avoid to offer the gerbers...this will create some kind of control to reduce versions.
Having one type of gerber offered, will control the whole stuff to avoid too much variations around the same theme.... keeping something as a reference to the model.... and this, posted long time, keeping it the way it was as original, increase the confidence into the amplifier.... having a lot of options, or variations, or customized schematics, then people feel the amplifier as a mutant...and why to build something today, that may be entirelly different tomorrow?.... then people will be waiting for this future time "the tomorrow" and will never be sure if that "tomorrow" already arrived or not..so..they do nothing!
regards,
Carlos
Alex is a very special guy into the Dx Corporation Staff
He is good, he is fast, a nice man.
Related Gerber files, to the DHR Turbo, go directly to Alex mm email...he is the one that may have it..but depends on him if he want to make it published or not.
I have nothing against to provide it to; some folks, several folks, or to everybody..he can even publish here if this is his will... he may decide...he is the DHR Turbo board designer, he is free to decide.
Problem is to keep it original...people use to have Gerbers and then change things and put their own personal name written into the board (forgeting the one has generated the first Gerbers and worked as an animal to provide the board for us).. and to write their own name is not fair, when all the hard work was made, in this special case, by Alex mm....so...if he decided not to give those files, i will support him even this way as make a lot of sense to me too.
I have Gerbers from Precision 1 and HRII..... i have not from Dx Amplifier and DHR Turbo.
http://www.youtube.com/watch?v=Ew7Sr1IA6h8
regards,
Carlos
This way is better, more correct, more decent, more respectable
behavior.
Read the red small letters..the example.
This is not only "To give to Ceasar what belongs to Ceasar"...it is also a decent position, as the one have made modifications must be responsable by their job, and can be accused and considered "guilty" if his modifications results bad and the board explode after beeing used by other folks.. say..if published.
If not to be published, not needed to print these things...it is enougth that you know the one made it first.
When a board is published, original and modified, must be tested in advance to be sure it will work fine, that no errors are still there to be fixed...it is an adult and responsable job that all of us must have concerns to respect other community members... we cannot give them a "time bomb"
Alex build...he has sure his board works fine..he has published pictures proving that he build and he had informed have listened...so..everything fine!... job done, entire and completed.
regards,
Carlos
If you appreciate vídeos, slide movies and youtube, the same as i love it
then visit uncle charlie small videos and picture...just type destroyersoueu into the youtube search bar.
I am a diyer, there you will not see business, only family pictures, local pictures and audio electronics..some nice musics too and audio tests.
More than 100 videos are there...enjoy and honored me with your visit.
Hi Alex,
I read all the posts here and found several board layouts done by you. I already purchased all the components to make DHR turbo. now i'm thinking which board im gonna make. can you help me sending latest modified version PCB layout and component layout which you made? my email is lycans@gmail.com
BTW I'm familiar with eagle PCB designing software. but when I look at your layouts, it seems like you are using another tool. So i'm not able to modify it for components which i already bought (only a few of them is mismatches) but i can arrange those with your last published design. so im planning to use that but still need a clear silk screen layout.. I appreciate if you can help me out of this.
Thanks in advance
A poor guy from Sri Lanka 🙂
The board to DHR turbo was made by Alex mm...and was published in this same thread
search for the board layout and if you want Orcad, or Eagle files go to Alex mm..i have anything about that at my home.
This was made with Alex mm kind cooperation...he is the board man.... i have made the amplifier... created, build and tested..boards layout and board test was made by Alex mm.
regards,
Carlos
I'm following Alex mm
Yes uncle carlos:cloud9:
I'm addressing to Alex mm.. I found his super design layout from this thread. but the silk screen he published here is not very clear. of cause i can use the schematic and fill the components but I can see Alex mm has changed some values compared to last schematic published by uncle Carlos (my surviver 😀) anyway.. i'm following Alex's board.. nice design Alex mm! and thanks Carlos for supporting 😉
You are welcome...soon Alex mm will send you what you need
just inform him your email adress.
You are entering the Dx Corporation (exists only in my dreams) crew as you are building, or intending to build, a Dx amplifier... send me picture from you to the hall of fame... the crew picture wall/hall at the Corporation headquarters at my Heart's City.
dxpanzerfausten@yahoo.com.br ... do not forget the BR ending, that means Brasil.... Yahoo Brasil...or BraZil if you prefere.
Please, newcomers are unknown people (for a while)... and we need some information, alike the town and country, your age, your professional skills or if you're an student, what school or college you are doing, your hobbies, how much skilled you are, your picture and so on.... the forum profile is helpfull to us to know how to talk with you... to adjust our conversation...to see if i have to say that 2 resistances in series add their unitary values or if i can just say .. "put them in series!".... you can be alike Einstein or something more normal... and i would like to know.... try to complete your profile into our forum and be happy with us... welcome and count on me to whatever you need.
regards,
Carlos
Dear Dr. Carlos
well.. i dont know how to introduce myself to you..but at this moment im a lost boy.. age is 28. I lost my job 5-6 months back and no income yet.. I was working as a software engineer for Virtusa in Sri Lanka. That is my country. and I lost my love. simply she dumped me after three years. its a love story like a drama and im not gonna talk about it caz its out of this topic. my first degree is for information technology and then I went through post graduate diploma in business management. even though I have those papers with me, I'm still like a beggar living with my parents. hope thats enough for my profile..
electronics and music (i express myself by my guitar.. my guitar may cry when i want to cry.. but i'm a novice yet) one of my best friends making speaker enclosures. customers who come to his place is asking for sub woofer amps and many things but that is not his business. He told me that if i can make those then he can sell those to their customers. currently im making a sub amp for him which i took from a magazine.
im not gonna sell DX amps without your authority. I dont know much about electronics but day by day im learning more and more. Thank you for your invitation for the DX corporation. I accept it without any doubts. I dont think i can contribute much more here but i can send some images what i make and do time to time. and I dont have a camera with me but my mobile can take snapshots so i can only upload low quality pics at the moment.
I can draw PCBs using Eagle so may be i can help you with that..(Not a pro designer like Alex mm)
I was searching amps and stuff through the internet and accidently i hit this forum i can see so many amps in the net but I see some difference with DX amps that is what i'm looking for..
My dream is to make amps for our country caz currently here they dont make any good quality amp like DX 😎
I love the way you address the audience with some silly jokes hehehe..
and of cause you are surrounded by pretty girls always 😀 thats you are so happy.. :cloud9:
Aluminium panel surface treatment to Dx amplifiers builders and all folks
Sometimes we have damaged, scrathed aluminium surfaces or plates..and we want to make it better, to rebuild or reform.
Then scratch it more using sandpaper... start with 120 grain and then go using 240, 360 and 500 grain sandpaper... use the waterproof one and do it with the aid of water..... you can use steel brush too, or a powder to produce
polishment in metal surfaces.
After that...clean and construct a brush (do not use the ones have metal parts to hold hairs in place)....use wood and your own hair, or horse hair, or dog hair.... glue or clamp the hair into the wood tip...there's your paint brush..or chemical material applier.
Use the chemical material.... Oxalic Acid (diluted)...or Sulfuric Acid and you can use something to produce a phosphate cover into the aluminium.
After that, wipe with water and let it dry..apply letraset or something alike and them paint using transparent automobile varnish (paint).
Be happy with your DIY panel.... see the slide movie made for you...published into the youtube:
http://www.youtube.com/watch?v=qUQGLNxoaHc
regards,
Carlos
Thanks a lot, Alex mm
I already prepared the PCB with my own hands 🙂 and I spent time adding components one by one.. now 80% of the work is done. i'm planing to include 3 pair of power transistors at the beginning. because I dont have a 56-56 transformer right now but 24-24. after regulation it will give around 35-35. So i think 3 pairs will be enough to drive that. im so tired now so better have a sleep and fix the rest :spin:
once again thanks Alex for sending your lovely layout and other files..
I am glad to know you Lycanlk, a very sensitive guy.
Do not tell me about dump as i have suffered from that 28 years long...not easy stuff...but mine had a happy ending..... a struggle, but i am the winner.
You are free to sell Dx Amplifiers if you have the chance, just do not forget to say/write in the board the trademark and my name...if the board is by Alex mm, them write Alex mm there..if the board is from Greg, then write the name there, if the board is from Nordic, then write the name there...and be happy!
Enjoy our forum and thank you by the picture... a very handsome guy.
Welcome and stay with us.
regards,
Carlos
i have made something wrong
Hi Carlos,
I gave 30-30 dual supply and i can hear sound like a headphone. transistors are cool (used only 3 pairs). looks like they are not driving. is it because of low voltage or i have made a mistake ??😕
Thanks,
Ranga
