This is not just another gainclone
They chosen like that because Riken isn't available in less than 0.5W, but if you use different type choose the Wattage that fits best between the pins of the chip (between - input and output). 0.5W is actually a bit too long. 1/8W Holco might be a good alternative.
I was advised by somebody in the hi-fi industry to try and use higher wattage resistors for feedback duty.
A good method with chip amps is to use two resistors in parallel so that they fit between the pins but provide a higher wattage rating. That's what I did with my Gainclones, using two Welwyn RC55's in parallel and they fitted between the pins perfectly.
gianclone schematic
Dear Peter,
I appreciate your experience, and would like to start building gianclone from your schematic as reference point. Please do not reefer to some post because I am little bit lost in all those infos and various schematic around the web. Please post (or send mail) of your schematic of that amp with heat pipes.
Thank you,
Ticovski
Nuuk said:
Basically, for better thermal stability and lower noise.
but with the added problems of a larger tollerance, greater effect of temprature on resistace and finding the right values of resistor
personally i would look into using large wattage reasistors that are the same size. such at some BC reistors which are rated at 0.6W in a 0.25W case
I don't think that doubling a 0.1% 15ppm tolerance is a problem and the thermal stabiility is increased not decreased isn't it :scratch:
For the sort of quality resistors that should be used in this part of an amp circuit, and with the advantage of using two values instead of one, there isn't much of a problem in finding the right value.
help needed
Hi all!
After my OTL monobloks I have made my minimalized Gainclone
a la Peter Daniel. Four transformer, hexfreds....
The sound is very promising, will it be better over the time?
I have one problem which I could not solved yet:
When the amplifier is powered off , there is a short hurting sound
from the speakers. I looked at it on my scope and there is an oscillation on the outputs for some milliseconds.
The amplitude is not limited (about +- 30v), but at this time the +- voltages were floating (not earthed). With 100 ohms to earth the amplitude decreased to some volts, but it is disturbing also.
I tried zoebel on the output, 22k, 18k grounding resistors on the inputs no result.
If anybody could help
thanks
George
Re: help needed
from the speakers.
George,
Four transformers, so probably you already built it stereo. Let me ask you first if this is sorta symmetrical for both sides. I mean if your GC is misbehaving the same way both on the left and the right channels.
PD was right, a photo and/or an detailed schematic would greatly help tracking it down. Just a hint: in case your transformers are center tapped, try temporarily feeding one channel with only one of them. Make your ps simpler for a try. But forget if it only has single sec. winding of course.
Could you attach the exact circuit of your ps? How the + and - sides are tied, particularly ground leads...
monguz
grounding problem
Hi Peter, Monguz!
The four transformers have only one - one secondary.
I have modified the original schematic a little , it is only one channel. V+, V- are +- 32V.
The sharp sound, oscillation is the same on both channels.
The 1000uF/35V capacitors are low ESR Yageo types, I can change them to normal BC type
George
my gainclone!
Just thought I would post a picture of my gainclone. It uses Peter's simplified circuit, although I'm considering changing the 4.7uf with 22uf. Has anyone else tried this? I also have not received my transformer yet so I have it running on lab power supplies in this picture. In the next picture are the complete chassis of the control and amp. When the trafo gets here I can complete the chassis for it.
