When will I find time to listen to music? Sometimes I find I am doing more listening trials than just enjoying the music.Anyone
thinking the same?
I don't think I could get quite so involved in the search for the 'ideal' sound for 2 reasons:
1) I have (relatively) 'cloth' ears. golden they aint..
2) my preferences change from day to day.
something that sounds 'spot on' on one day might feel too laid back the next , or too vibrant and in-your-face. Some days I want a lazy warm laid back sound, other times I want in-yer-face forward sounds.
whats a guy to do?? make a bunch of 'clones and grade them like wine, so I can select the right one for my mood ??
hell, they're cheap enough , unlike the Lab47 ones...
ray
thinking the same?
ray
Nuuk said:
In a review of capacitors in the Electronics World magazine, Cyril Bateman found that for some values, two non-polarised capacitors used in series measured less distortion than a Black Gate!
etc.
Nuuk,
Is this review available on the net? Made me curious to read it. Google did not help, everyone is just referring to the original series of articles (Capacitor Sound if my memory works correctly), but no luck.
Thank you, regards
monguz
Well I tried battery power today with two 12v .I had no volume problems with this set up.I noticed better soundstaging , more "air", and very natural sounding upper registers.Sound was a little bit more laid back and further back in soundstage but with excellent definition and no problems in the bass.AC sounds louder and more up front and dynamic but with less layering and separation.
That's interesting Protos as it agrees very closely (if my memory serves me correctly) with Hi-Fi World's description of the Final Analysis Music5/Music 6 combination.
I'll have to dig out the article and re-read it.
And if we can get away with a couple of 12v batteries and a charger, that's not too much more outlay than the transformer and the diodes.
Banned
Joined 2002
Olle Bard said:ok, so if i have a "reliable" source i dont really need it.
i was shopping components for it yesterday and the guy in the shop said it would cost 4$ and thats more than i paid for the ic so.
how do you make sure the source doesn´t produce any DC?
4$ each that is cheap i paied 12.00 each for my caps for my preamp.
Not everybody wants to use top notch parts like you So you spend something like $200 just for the caps?
Olle Bard said:how do you make sure the source doesn´t produce any DC?
Check with a meter on the output jacks.
Re: batteries
You're not going to fry the amp. While car batteries can put out a lot of current, any voltage source only outputs current based on the load that it's feeding. You're worst case scenario would be if the amplifier were full on and if it's connected to an 8 ohm load, you're talking a whopping 1.5 amps.
se
vic said:How does one connect the batteries so that the amp doesn't get fried? Wouldn't the current need to be regulated? Car batteries can put out lots of juice.
se
battery power
Thanks for the reply.
So let me ask. Why don't more people use battery power? You can get decent car batteries at Sears for say $50 apiece. Use 4 of them giving 24 volt rails per side. Use a trickle charger to charge them between usage. I have a nice charger that I bought at Cosco for about $30. I'm sure others have thought of this. I'd like to hear if people are making automatic charging units, etc..
vic
vic
Re: battery power
I've no idea why more don't use battery power. Particularly with Gainclones as it's natural for it.
And you don't need to use huge car batteries. Not with a realtively low power class A/B amplifier. 10 or 12 Amphour SLAs will work just fine. As for chargers, while a simple trickle charger will ultimately work, a bit more sophisticated "intelligent" charger will get more performance from the batteries.
In the meantime...
<center>
<img src="http://www.q-audio.com/images/noac2.jpg">
</center>
se
vic said:So let me ask. Why don't more people use battery power? You can get decent car batteries at Sears for say $50 apiece. Use 4 of them giving 24 volt rails per side. Use a trickle charger to charge them between usage. I have a nice charger that I bought at Cosco for about $30. I'm sure others have thought of this. I'd like to hear if people are making automatic charging units, etc..
In the meantime...
<center>
</center>
se
Banned
Joined 2002
Yes actualy i did because i wanted the best pre amp that i could build and i said to my self why put crap parts in it now and then change them later when i can do it all right now.
For that money I would have tried volume transformers (passive)...
Fedde
- Chip Amps
- This is not just another gainclone
