I’m not sure as I don’t use preamps, there are several proven, popular builds on here though. Just make sure it can output minimum 1.7V rms.
Not sure, I'm not knowledgeable enough to read the schematic, and there are no specifications anywhere in the documentation. The documents mention 1V output a few times, so I think it's just a little shy on power for Wolverine. Someone else here will know where to point you (I don't use preamps) 🤓
EF3-3 V5 prototype up and running!
Hi Guys,
We’ve got some fantastic news for the Wolverine 5th Group Buy! A huge shoutout to Gianluca from ModuShop for stepping up to support our project in a big way. Not only is ModuShop offering a 5% discount on all 3U, 4U, 5U Dissipante and Mini Dissipante chassis, but Gianluca is also providing custom heatsink drilling for the following Wolverine board patterns at no extra cost:
To grab this deal:
If you have questions or need help with your chassis order, drop them in this thread or reach out to me at stuartmp@internode.on.net. The 5th Group Buy is shaping up to be our best yet—thanks for your enthusiasm!
Best regards,
Stuart (stuartmp)
Wolverine Team
- EF3-3: TO3P, TO264
- EF3-4: TO3P, TO264, MT200
- EF3-5: TO3P, TO264
To grab this deal:
- Visit the ModuShop Chassis Collection.
- Use the discount code DIYWOLVHF2K at checkout to enjoy the 5% savings.
- Specify your desired drilling pattern on the website (EF3-3, EF3-4, or EF3-5, with TO3P/TO264/MT200 as needed).
Best regards,
Stuart (stuartmp)
Wolverine Team
"Not only is ModuShop offering a 5% discount on all 3U, 4U, 5U Dissipante and Mini Dissipante chassis, but Gianluca is also providing custom heatsink drilling for the following Wolverine board patterns at no extra cost:"
Hi Stuart,
Great news indeed!
I do have a question though, it looks like adding the Wolverine drill pattern to a 4U 400mm case adds 70€.
Is this correct?
Hi Stuart,
Great news indeed!
Is this correct?
Maybe I miss understood. I will ask @Gianluca to confirm.I do have a question though, it looks like adding the Wolverine drill pattern to a 4U 400mm case adds 70€?
Is this correct?
And for anyone with existing "standard" diyaudio UMS heatsinks:
For 1 Channel. All boards have some common holes that line up with UMS so getting started with the PCB as a template is easy.
300mm deep:
EF3-3 with TO-3P outputs - no drilling required
EF3-3 with TO-264 outputs - 6 additional holes (outputs)
400mm+ deep:
EF3-4 with TO-3P outputs - 6 additional holes (pcb and drivers)
EF3-4 with TO-264 outputs - 14 additional mounts required (pcb, drivers and outputs)
EF3-4 with MT-200 outputs - 22 additional mounts required (pcb, drivers and outputs)
EF3-5 with TO-3P outputs - 16 additional mounts required (pcb, drivers and outputs)
EF3-5 with TO-264 outputs - 16 additional mounts required (pcb, drivers and outputs)
300mm deep:
400mm+ deep:
Thanks for the detailed information post Stuart! The coupon gives a flat 12,5% discount to all the 400mm deep Dissipante/MiniDissipante chassis and Wolvering heatsinks substitution (which is 60 EUR and not 70)
Depends on your target rail voltage and how many output pairsWhat output transistors are we recommended for the V5 with a Cobra S2 Smps?
In my case, the coupon deducted 41 EUR for the 5U Dissipante + baseplate + substitution back panel + heatsink substitution + set of four feet.Thanks for the detailed information post Stuart! The coupon gives a flat 12,5% discount to all the 400mm deep Dissipante/MiniDissipante chassis and Wolvering heatsinks substitution (which is 60 EUR and not 70)
Am I missing something?
Feet, baseplate and back panel substitution are not included
Hi all, I noticed in the diyAudio Shop that there is a new chassis for sale: the
Does Modushop offer this option as well for their 5U Deluxe chassis?
Wouter
2025 Deluxe Chassis - 5U
with the option of engraving the front plate with a "PASS diy" logo, some waves and lines and two holes for LEDs.Does Modushop offer this option as well for their 5U Deluxe chassis?
Wouter
- Group Buys
- The Wolverine 5th Group buy
