"The Wire" Ultra-High Performance Headphone Amplifier - PCB's
opc
Joined 2004
I would second what regal just posted. You'd actually get a little more voltage swing out of that arrangement, and possibly slightly better overall performance. I know there are a lot of rework SE-SE PCB's (some people have like 8 of them) so I'm sure you could score two of those.
I would offer something up, but I honestly don't have a single board left except my personal one!
Owen
I suppose there will be no more group buys, it's a shame, because it looked very interesting... :(
Just out of curiosity, the SE-SE version of the wire would have been able to drive my AKG K1000s ?
I am interested too, could drive a SE version the K1000?
The K1000 have 120 OHM, but need some voltage :eek:
PS: Today I use a GSP Solo (use only single 15V power), with an adaptor cable, but cannot drive them very loud.
You missed a difference. check the rail voltages.
LME49600 -> +/-18V
LME49610 -> +/-22V
IF you are willing to upgrade other components on the board and take more than 18V from your power supply you get a few more volts swing on the output. Are your headphones performance limited by voltage? (rhetorical question that after you have answered will give you the answer you are looking for)
If you take the time to check the schematic you'll realise that some of your options for BW aren't valid.
LME49600 -> +/-18V
LME49610 -> +/-22V
Using LME49860NA for frontend this amp should be AKG K1000 (not in bridging mode - using a jack to XLR adapter) ready.
http://www.national.com/images/pf/LME49610/30042540.jpg
It was only a quick check :rolleyes:
PS: I am searching for a PCB about - using no SMD parts.
It's not pretty, but it'll work until someone makes something better.
It uses the (similar) TI BUF634 in place of the NS LME496x0. If you don't like that, just rename the component in your schematic/board. ;)
There's also some additional stuff in it, like the OPA1632 and virtually all Neutrik XLR pinouts. But the latter can also be had from the official CadSoft libraries.
  • OPA1632+BUF634.lbr.zip
Input over voltage protection (OVP) with schottky diodes or 2N3904?
I'm curious if you guys (and hopefully OPC too) can comment on using diodes to protect The Wire (BAL-SE) from input overvoltage from upstream gear with higher rails, which could be accidentally (by human error) turned up very loud, and therefore be capable of higher output voltages.
There are a few documents outlining how this might be possible (such as this app note from Analog Devices), but actual implementations seem oddly rare. The general consensus seems to be low-leakage schottky diodes such as BAT-85 (or even 2N3904 wired as a diode using just CB and leaving the emitter disconnected). There are also special devices that exist for this purpose such as the ADG465, but the data sheet mentions nothing about distortion, and the ADG465 isn't popular on this forum, turning up exactly 0 (zero) times after a quick search!
So is it possible to maintain the ultra-high performance of the Wire, maintain the headroom, and somehow have trouble-free input over voltage protection? Attached is what I think might work, but I'm unsure about distortion...
PS it's at times like these I wish I had a super AP test rig :)
I'm currently playing with the attached idea. I stumbled upon it at THAT Corp. (in a design note and an AES paper) and later discovered it in some projects (i.e. a preamp by Uwe Beis).
The general idea is that the protection bridge is biased into not conducting under normal circumstances, as opposed to a diode that is directly attached to a supply line.
It should be noted that neither National (LME49990) nor TI (OPA1632) are telling us much about the internal clamping diodes at their ICs' input.
To be honest, I never actually heard a difference between diode circuits at amplifier inputs (nor did I ever try to).
