"The Wire" Ultra-High Performance Headphone Amplifier - PCB's
:mischiev:
cool will do, its a nice idea to have them all together, but that brings issues of where to place it, i wonder if 'the wire' amps could be the first non-commercial sub-forum? so probably its best to start 2 threads, one here with the headphone amps and one in the solid state forum for the other 2. i mean the headamps safely fall under the solid state banner, but people looking for the headamp build thread may not find it, hmm ahh but your link will help this. i think i'll start 2 and if we think its a good idea i'll get the mods to combine them in the solid state forum.
i'll get some better pics later, but i'll start the threads now, thank god for the eternal edit on first post
Two separate threads would probably be the way to go... two very different applications! There were also many people who only bought one or the other, so they probably don't want to get notifications for an otherwise unrelated project every day.
Owen
It has been discussed, not sure anyone has got a hold of any and tried it.
You'll be changing caps and using a higher voltage supply then? What are you driving that you want the higher voltage output for? Or was there some other spec difference between the 2 that I have missed?
Need help. What value of potentiometer should i choose for The Wire SE-SE? I want to buy DACT 21 step 1% smd resistor attenuator and there are values: 10K, 20K, 50K, 100K, 250K. As I understood more resistance gives better control at low level of volume and low resistence like 10K gives better control at high volume. So maybe I should take something like 20K or 50K ? Suggestions are welcome.
Hi TiEx,
The value of that pot depends entirely on what your source is preceding The Wire. If you're driving it with a modern piece of solid state gear, then 10k is probably the best choice. If your source is tube based, you might want something higher, and will need to figure out what the output impedance of your source is.
Generally speaking, all these pots should have the exact same log-taper, so what you said above about different resistances giving different attenuation at different levels is probably not correct. They should all be the same.
The main push to use lower resistance units is purely noise, as the lower value resistors have lower inherent noise. Using a higher value of resistance than you really need will add noise to the system for no reason.
Regards,
Owen
Hi TiEx,
Regards,
Owen
I am planning to use something like iBasso D7 which outputs a true line out (2vrms i presume) and very low output impedance. Can I ask you what value you are using in your "The Wire" amp? I see many design in internet use 20K pot for headphone amps. Maybe I should go for 20K to be more compatible with wide selection of sources?
Thanks for the info. And for the 2 SE-SE pcb's! Looking forward to build and use it. Will update on progress to help others! 🙂
he, like several of us do not use a pot at all, we use the inbuilt digital attenuator in the dac (several dacs allow this including es9018, es9012, wolfston wm8740/1 etc)
That's exactly correct, and also recommended, but if I didn't have that option, I would use a 10k stepped attenuator and omit the input resistors on the SE-SE PCB.
All modern gear should be able to drive a 10k load without issue, even tube gear. If it cannot do that, I would step out on a limb and say it's probably not worth using.
Regards,
Owen
yep 10k is a good median value, but i would avoid ebay fake dacts and buy the ELMA MV series stepped unit with the thin films. in fact it appears they make the dacts for dact under license, so cheaper to go direct. is this for a portable unit? not many high quality attenuators that will fit in a small enough case for portable.
I have a good question that might be interesting to many people here.
Can BAL-SE and BAL-BAL versions of The Wire be used or adapted to work as an I/V stage for DAC like AKD12P from Acko? And if yes then can someone provide an implementation scheme on how to do this.
And the second question can this setup perform two roles and serve as I/V output stage and as a headphone amplifier?
Maybe this idea is not first around here, but I sure think it can be very useful.
I found that opa1632 is used in Anedio D1 based on es9018 and in TwistedPear The IVY III Balanced Linestage.
P.S. Very little familiar with diy but as far as I know, some preamps can serve as headphone amps. Maybe these "Wire" gems can do more than just drive the headphones. Anyhow if someone have an idea of similar kind I would like to hear it.
TiEX: I guess you havent been reading my posts, i'm not going to do a guide, but yes its possible, though for best performance with es9018/2 you shouldnt populate the input resistors and lower the feedback resistors to 680R. no its not the first time someone has mentioned it, ive been talking about it since the beginning of the thread and even posted pictures and a description in the build thread I started
Nevod, i'm not opc, but i'm saying no and if you have a diy process to make your own 3-4 layer pcbs i'm all ears. it is unreasonable to expect that everyone on this site give away their intellectual property for free
nope, this is only when using the amp as combo IV stage/headphone amp and particularly with sabre if you want to remain as much in 'current mode' output as possible. the input resistor does not exists in the sabre or for that matter acko or TP IV schema and RG would be 680R for unity gain. this way you basically end up with a buffered current mode sabre IV stage, which also drives headphones rather well
