The SLB (Smooth Like Butter) Active Rect/CRC/Cap Mx Class A Power Supply GB
@xrk971
Did I understand correctly ?:
1. For example, to M2 / M2X, it's better to use 2x single rail (one for V + second V-)? Then I need to use 2x 22v on the transformer winding to get +/- 24VDC?
2.Is standard 2x18 V transformer for Firstwatt insufficient to get 24vdc?
3. maybe the best option is two pcb dual rail?
Founder of XSA-Labs
Joined 2012
Best option is use dual rail x 2 PCB with two trafos. You need 22v trafo to get enough voltage after sag and drop in cap Mx.
Next option is single dual rail with star grounding for everything (signal, speaker, amp return).
Single rail option is only for single rail Class A amps like ACA or MOFO or for using as clean power on RaspPi etc.
Founder of XSA-Labs
Joined 2012
The SLB boards have arrived
The nice DHL lady just dropped a 16lb box off on my doorstep.
These look really nice. Kudos to Jhofland for a terrific layout.
A great amp to pair these off with is the Alpha 20, which I just received a fresh set since they ran out. You can get those direct from my shop. I plan to build up another Alpha 20 soon. I think Vunce maybe doing the same thing too.
The SLB SR is a great PSU for the MoFo or other single rail amp.
Joined 2011
X,
If there's still room in the BG, I will take 2SLB and 2SLB-SR
baswamin - 2 boards - Paid
meanie - 2 boards - Paid
jwjarch - 2 boards - Paid
gary s - 2 boards - Paid
nautibuoy - 2 SLB boards - 2 SLB-SR boards - both Paid, ship together
antoniopf1972 - 2 boards - Paid
ravid - 2 boards - Paid, Simple PSU Paid, ship at same time
Gricko - 2 boards - Paid
poseidonsvoice - 2 boards - Paid
Bkdog - 2 boards - Paid
Jazzfan - 4 boards - Paid
yoaudio - 2 boards - Paid
van of monks - 1 board - Paid
Wtl - 4 boards - Paid
cerole - 2 boards - Paid
s610adam - 4 SLB - 6 SLB-SR - Paid
pbergstrom - 2 boards - Paid
ferret - *3 boards* - Paid
Roundtoit - 2 SLB boards, 2 SLB-SR boards - Paid
Tubesguy - 1 SLB board - Paid
Kokanee - 8 boards - Paid
Arthur - 10 boards - Paid
potepuh - 2 SLB boards - Paid
TboneAK - 2 SLB Boards - Paid
Sanjeevm - 2 SLB Boards - Paid
Centurion53 - 1 SLB board - Paid
Vunce - 2 SLB boards, 2 SLB-SR boards - Paid
Shawnstium - 1 SLB - Paid
*Ermine22 - 4 SLB boards - Need to know if want exchange for lost previous GB
Skunark - 2 SLB boards, 2 SLB-SR boards
Founder of XSA-Labs
Joined 2012
GB Status Update:
Ermine22 - 4 SLB boards + ppm HPA - Paid
*Skunark - 2 SLB boards, 2 SLB-SR boards - Invoice sent
*finneybear - 2 SLB - Need PayPal address
