Salas, thanks for the picture. I believe it would be easier if I put it on a picture too.
Here's what I meant (see attachment).
How would I connect, on the one side, the batteries, on the other, the phono stage?
are boards available
Hi Salas,
Can these boards be purchased ?
Thanks,
NS
You can still use C105, C205 even if having a smooth battery DC input I mean. It can do good bypassing the battery feed. Your preferred quality 1000uF type will suffice.
Hi Salas,
Thanks,
NS
Hi Salas,
Thanks,
NS
There was a very recent conclusive GB but it ended. Ask Tea-Bag in case he had ordered any spares.
Thanks, Salas. Good thing I have asked you.
Alternatively, would it be ok to use only one battery for both boards with the same phono stage?
Hi Salas ,
Thanks for the reply,I found 2 boards or 8 ps boards they are the RED v 1.0 do I need any mods to them or just put them together,I forgot I had them,LOL.
Thanks again,
NS
I meant using just one 36V battery for the whole system, instead of using two (see attachment).
No
post6204,
Salas, keep the two 36V battery packs separate.
The Zero Volts connect at the other end.
i accidentally put the op-amp in backwards in a 15+- shunt and the leds only came on for one side. when i corrected the opamp's orientation the circuit operated again but i wonder if something has been damaged. because though i don't know since when, the amp has developed a hum+ channel bleed.
Do other checks then. Use a DMM in AC mV and see if there is ripple in the rails.
If there is, check if something went out. The transistors and Mosfets in the regs must show about 0.6V VBE and about 4V VGS when they are OK.
- Power Supplies
- The simplistic Salas low voltage shunt regulator
