The MONGREL (supersym II)
but that never happens in this industry 😀
does C86 need to be 22uF - a smaller value allows use of a higher quality cap ?
Mr. Self likes 22u , I use a 22u presently. I have seen anywhere between 47u and .1u on commercial designs. As we are just decoupling a simple shunt regulator, "just adequate" quality will do ... no blackgates on my Vbe , please. 😀
OS
Yes, Pete,
It DOES matter, and a 22uF 6.3VW BG NX cap in this position DOES sound superior.
Which irks me, because they take time to bed down, and they are EXPENSIVE.
Smiles all round....
Hugh
I read that they are no longer in production. 🙁 Where I do see them is in esoteric "audiohaus's".. where they want your soul in return :redhot: . They are made with carbon "doped" electrolyte , right ?? Have you researched an alternative ??
OS
No, not at this stage. But I bought quite a few about five years ago, and still have some left, which I treasure. They are very useful for the ultimate low noise application.
It is never nice to be reminded that some of these audiophool components are actually very, very good. I have found that electros specced to 100KHz for switch mode use are excellent for audio, and well priced. UCC make such a range.
Hugh
Hugh
Funny you mention 100k , I was sourcing the signal path caps and came across these from panasonic (the EE or FM series) http://www-images.panasonic.com/industrial/components/pdf/ABA0000CE108.pdf
for modern switching apps. and cheap , Mouser has them (33u@35vfor $.11) very low impedance at HF.
OS
Os I was thinking of asking keantoken to sim a vbe multiplier using a darlington and make the same comparison he did in the aksa thread. Im trying to find transistor models for the darlington at the moment. I dont really know what to say about the outputstage, In all the years I still havent built anything with quasy outputstages.
I don't know if having a model for the darlington will matter, a 2N5089 driving the usual transistor used here would probably work.
But if I were to predict, I would say that the results at AC won't be much different than those of the C-B capacitor mod. In both cases a hurdle overcome is the Ib of the transistor. The Darlington uses a whole other device to fix this, with little impact on other factors. For instance, the resistor network reduces OLG of the stage by its ratio. The cap mod fixes this as well as the Ib problem by adding only 1 passive component.
Gm is still the same, which is the second hurdle. Compared with the cap mod, using a darlington is still worse, and with the cap mod added to the darlington, performance is still about the same.
A better option is to use CFP instead. This reduces Gm as well as Ib, and sims much better. Add the cap mod and it works wonders.
Sims to follow, let's see if I'm right.
- keantoken
Here we go.
The plot is impedance in ohms.
I think I was right! Interesting to note though, that at first the single Vbe multiplier was the worst option with lowest HF bandwidth and now it's nearly the best, and has the best HF bandwidth.
- keantoken
impedance range ~ 0.8ohms to 200ohms.
Can I assume that lower AC impedance is better for a Vbe multiplier?
Why is V2 the lowest impedance between 7MHz and 280MHz?
Does that matter in an audio amp?
What effect does adding the bypass cap have on each?
Lower impedance is better, as far as I can tell.
At the frequencies you describe, adding any more active components will only degrade performance in my experience. This is why the single-transistor version works so well there.
The darlington doe have better DC impedance, but CFP is most "bang for buck". Although instability might tip the scales a bit.
I'll add a bypass cap, 22uF .02ohms 22uH and see how that goes.
- keantoken
Wait a sec, I neglected cap parasitics the first time around. The first plot are the results. This assumes .075ohms ESR, 22nH ESL, 22uF. ESL is worst-case.
Second plot adds the same spec'd caps as bypass. I thought the spike would be worse, since using the same caps adds the same resonances, and the caps will resonate supposedly, but it turns out the resonance comes from the 22nH resonating with the BD139's Cob.
BTW, OS, how do I upload to the site? I made a digital instrument that sounds really nice with Bach, which I'd like to share (It's somewhere between a harp, harpsichord, guitar, and piano). Think "Switched-On Bach" except with only one instrument. I thought I'd upload a few and if there was interest I could upload more.
- keantoken
- keantoken
So.. the single transistor vbe with the cap mod is the winner. 🙂 You can upload here : HFS / This is the "root" of the server. Click the upload folder , a upload button appears on the top right .. then , just like DIYA "manage attachments" , 10 "choose file" buttons appear. Digital instruments are cool 😎 , check out my signal generator/instrument (below) Could not blow the "supersym" even with all those waves. 😀
OS
A 33 ohm resistor in series with C1 or the "cap mod" works. That is assuming that by the time the amp is on the PCB, we will have any control over resonances at 200MHz!
The file is uploaded! Look in the Uploads folder at OS's website for BWV973.mp3, and please tell me what you think! I may be able to improve the sound by rendering differently.
- keantoken
