The Mini-A
korben69 said:
I'll try to ship your 2x3R this week.
Seems they are awaited... I'm looking for 2 terminal blocks 7.5mm for the PSU board 😉 [/B]
Will be looking forward to them, thanks!
Terminal blocks you say? I'm looking for terminal blocks too... I ordered terminal blocks for all inputs and outputs and was unpleasantly surprised that the AC inputs aren't 5mm spacing. 😡
I've held a white coloured terminal block last weekend but wasn't sure it had the right lead spacing and if it would fit without interfering with the LED diode and the rectifier heatsinks. I'll have to bring my PSU PCB with me to see if they will fit. If they fit the PSU board I'm more than willing to supply you. 🙂
Beftus said:
Progress!
Finished! Will try to find fitting terminal blocks for the AC inputs.
Nearly there. Still to do:
  • buy & install matched Q1 and Q2
    buy & install C4
    wait for & install R0
    install Q6 and Q7
q 1-2-3 should be matched together 🙂
Progress report for my MiniA PSU, tested today.
Configuration
Transfo : Antek 3212 / 300Va 2x12V (12.34)
Diodes : MUR 1560
Caps : 3x12000/63v per rail
Bleeder Resistors : 3.3K/3W
1 x 0R47/3W on each rail
About 16.58v at the output with no load on both +/-
Cut-off frequency : 28.22Hz (Thanks Beftus 😉 )
Seems to be fine, any opinion ?
I agree with Jleaman : Q1-Q2-Q3 should be matched...
