The Kuartlotron - keantoken's simple error-correction superbuffer
I had some resistors bringing down my voltage just a hair (big resistors). I've got to say that I pulled them out because I was experiencing some problems with the volume I was trying to play at. Now that my voltage is a bit higher, I can play without that problem. It's my opinion that the voltage recommendations are too low unless you have 91db or better speakers.
I have a 2x12v transformer, and in retrospect I'd love to increase it - probably will at some point.
I'm using the older boards that had the error between some pico cap and resistor, without the regulators.
