The food thread
Yes the air traps make it easy.
On the left we have beans getting ready for black bean sauce, and mini English cukes on the right for pickles.
Reactions: tonyEE
I bought a slicer hoping it would allow me to cut uniform slices of bread from large home baked "boule" loaves. To make spiffy panini sandwiches and the like.
Unfortunately it wouldn't cut a 15mm thick slice, nor would it accommodate a 300mm "long" piece of material-to-be-sliced. (loaf diameter is 300mm). The horizontal "throw" of the sled holding the material-to-be-sliced was too short, and the portion of a slice-in-progress that had been cut would slam into the substructure holding the blade.
Boo
_
Mark J., not sure how often you check in here but I have learned some things about the new slicer that are not in the owners manual.
First pic is the seeming lack of room on the sled.
Second is the area on the feeder slide that allows you to open the 'grabber' all the way, including locking it out of the way so you have full access to the sled plate. This only happens at a certain part of the grabber slide. Not if it's close to the back panel.
Third is the spikes on the bottom of the grabber that gave me a clue to what is not explained in the owners manual.
Eye of round on sale today.
Dressed and seasoned, now serving time in the food dungeon.
Not sure, it could simply sit for two weeks and then dry cure for a couple months, or...
...leave for a day, then immersion cook and use as sandwich meat, thinly sliced deli style.
What would you do?
