The dumb-O-tron
The magic is in the circle
Started building this today.
Hopefully have it finished by tomorrow.
I will release the circuit if it sounds good
Wasn't sure what was going on here. I thought I might have had a ground loop, or maybe I needed teflon pcb material.
In the end I worked out what the problem was.
Just needed a screw driver.
Just got it up and running, but the bias jumps like a rocket when I plug the xlr cable into the amp. Need to think what the hell is going on. Not sure whether the signal input should be grounded through a resistor. The supplies are floating
If you have Jfet input, any preamp offset would affect bias. Rothacher talked about importance of signal grounding as well as symmetry of two sides to maintain balance. Without circuit, just guessing. With circuit, still guessing:rofl:
