It has become a no brainer for me that that everytime I see a RC4580 or for that matter even the NJM4580, I rip them out and replace it with a LM4562.
Lol cheers, I have a couple here and I thought they seemed ok, at least to replace tl072 is some applications.
What about LME49860?
It is my favourite, new and improved version of LM4562.
Haven't tried them. As of yesterday, the OPA1642 has become my new favourite. It's expensive though.. :|
Did you hear an improvement, or did you measure a difference?What about LME49860?
3h of listening/tweaking. My opinion has changed.
No, you adjusted to the "new" sound then your opinion changed.
I've heard all the op-amps mentioned here and their performance/sound will depend upon the application and the surrounding circuitry.
Still these op-amp "rolling" threads are fun to read, though.
LOL.
I just "downgraded" to OPA2132P after many months of using "high end" duals and singles on dual adapters (such as LME49710HA x2 , OPA627 x2, LM6172, etc.)
The result: I absolutely love the OPA2132P. I've owned it for well over a year and never really gave it much of a chance because I had so many other "awesome opamps".
Pffft.
Pffft.
3h of listening/tweaking. My opinion has changed. Putting OPA1612s in the entire path makes a lot of difference. Previously, the OPA1612s were still colored by the other OPA2228 and LM4562 in the path.
After changing every opamp in the listening path to OPA1612, the neutrality and precision of the OPA1612 really shines through. I'm putting OPA1612 now ahead of OPA2228 and LM4562 respectively.
OK, which one is the best now OPA1612 or OPA1642??
The bandwidth is an intrinsic part of its performance and a crucial aspect to consider when choosing a device for a given application. So bandwidth is just one aspect of performance that defines the whole device.
Take a 3 amp fuse and ask 'does the 3 amp rating of the fuse affect its performance' ? Its the same type of question.
What about OPA827AID? I have a few surface mount devices, ii could use with DIP adapters...
A few LME49710/20/40 Ha
A couple LT1115..
A couple of OPA2132.
INA217.(maybe not useful in this case)
Ive been building an active crossover, initially based around ne5532 then LME49740 for all stages, both the buffers and filter stages.
I really want to try a set of LT1028
What suits best...
A couple LT1115..
What suits best...
Will do fine... I use the, slightly faster AD826 as an IV, which sounds much, much better than the 2604 I used before. More detail, good balance between highs and lows and good dynamics.What about OPA827AID?
The LT1028 appears to be on about the same level, but I haven't tried that one since I'm plagued by a tight budget for this hobby...
How it performs compared to the LME's I can't tell either.
I'm plagued by a tight budget for this hobby....
Me also, and I have a few OPA827 purely as they were bundled with the last TI samples I got, some time ago. LT1028 looks interesting,but they are costly, as you say.
- Member Areas
- The Lounge
- The Best Sounding DUAL opamps
