TGM8 - my best amplifier, incredible bass, clear highs, no fatigue (inspired by Rod Elliot P3a)
Yes, well spotted - its an old E-I tranformer salvaged from a broken AV receiver. It outputs 60VCT, which translates to approx. 40VDC rails loaded. There are no power ratings printed but judging by the size and weight I would estimate 150-200W. A powerhouse by no means but ample for casual listening.
When I buy (as opposed to salvage) transformers I opt for toroidals due to availablily and cost/weight considerations. You'll see with most of my builds that I mount the heatsink inside the case, positioned between the transformer and amplifier boards / low level signal carrying leads. My theory is that the big lump of aluminium and physical seperation helps shield the circuit from EMI originating from the transformer. I've built designs that end up with a dead silent noise floor when other constructors report problems - so I'm inclined to believe there is credibility to this theory.
PS: I'm working on your boards and should have them finished soon ;-)
Can any body help me on P68. When i watch carefully the P68 schematics C11 capacitor is missing there. I am creating P68 by custom designed PCB. But can't recognize C11. Probably C11 will be between collector of Q4 and D2. Please help
Quote from Rod's public P68 page:
"C11 does not exist on this schematic, so don't bother looking for it. It was "mislaid" when the schematic was prepared, and I didn't notice until someone asked me where and what it was supposed to be. Sorry about that."
If you have purchased any of Rod's products you will have access to the "construction pages" that have all the details for construction of this amp including the location of C11.
regards
I am building 5.1 Home Theater using P3a(5 channel) and P68. I want to use this Home Theater for watching Movie by 3D Blue ray player and Samsung 3D Smart TV. In the TV audio outputs are LR Analog and Digital Coaxial. Can any body which will be better LR Analog or Digital Coaxial?
Agreed. I hope i will use 5.1 Audio Gear Dolby Digital Sound Decoder. But i found some decoder has Optical (SPDIF), Coaxial, LR analog as input and it's providing 5.1 analog output. All these are availabe in my TV or BD player. I want to know which input type will give me best audio experience. According to that i will finalize the 5.1 Audio converter.
Hi Bigun, sorry to do this to you but which do you prefer, musically... your TGM7 or TGM8... thanks 🙂
Hi Ranchu32, can I ask what other amps you have compare the TGM8 to and what would you say are the best qualities of the TGM8 and what are it's negatives... thanks 🙂
AHsJFJhC1JVdTiwNFHjIzQRYghQooATggIBTTTRlyNVL0Z4COQLoGuCnQgAduFxBEWgoDaMibGzFWSPmU4csj+wM1PKj1okIIUjp6WEESB+BGGKhQHUrj5U6CaosGTVmjgxZfDhtogIpxgAJAgBgmZTpC5kNAxkcmaIq1B1PgSotWCgQzyIagHx4afCnFZqFdF5IKWCKgGENQxAxKdGi1yBCpWrMCCDCAC0TAdrsuGRDyAcYFIJ0QSDAAIIEiQBEYpWEh5JXTySZAQBmxYADD8KQaOQCTi8cXFZ5cGRBDYRUZd6AuiFnIIhOW1QQucCBFxJMLM7QFTgiioNZheYuAgwIADs=
Hi PingPong
I'm very pleased with the TGM8 boards I've made, so much so that I built a stereo amplifier in a nice case for my living room.
I've built several P3A amps (experimenting with different component substitutions), VSSA, DX MkIII, and others that don't come to mind at the moment. This design of Gareth's is definitely one of the best. I have made some listening impressions in this thread.
Since you are in Australia too, I should mention that I have a few spare boards if you're interested - Gareth and I each ordered 10pcs from his board house. Happy to pass on a couple at cost price if you decide to build.
Just an fyi - TGM8 doesn't require any matched parts 🙂
Note that if you want to get full functionality from the speaker output relay indicator LED, it needs a small 'fix' (read back through the thread for details) if you want to mount it on the pcb.
Also suggest you are particularly careful to ensure you solder the power devices to the board only after first mounting them to the heatsink so that they are all held flat and co-planar before you solder their leads. Once soldered they are almost impossible to remove without clipping their leads off and removing the stubs left in the holes one at a time - this is an issue with any through-hole-plated pcb by the way and is not unique to TGM8.
