TGM2 amplifier
Node unconnected usually means it can't find the model for the model...
Try adding a normal transistor to the schematic, with "Q2SC3423_e" where the transistor part number goes. This should cause SPICE to include the standard.bjt file I included in the simulation.
EDIT: there is already a redundant transistor you can use, shorted out on the negative rail. Replace "2N5089" with "Q2SC3423_e". This will make SPICE look at the file I included, hopefully...
- keantoken
Yes, there have been some troubles... It was stable and playing well for several months without oscillating into a 5.6ohm fullranger. I then built another which ran just as well. All my latest have been worse. The difference, as far as I can tell, is lead length. In my earlier prototypes it was below 1cm for the important parts. Since then it has grown to 3cm.
Advantages? Hmm, go to a fancy restaurant, flash it in front of the smartest looking guy.
smart looking guy: No, no way.
me: look again.
smart looking guy: no!
me: I built it. It works.
smart looking guy: ...really?
A week later I have lots of money and lots of women!
- keantoken
Bigun, my philosphy changes from time to time. My first poweramp will have an open loop gain of below 60db, I'm sure. I recognize the correlation between OLG and SQ is probably negative at best. I just like the intrigue of designing "high-performance" circuits.
- keantoken
Hello keantoken
In the past, I was sim my amps for high OLG and so it was needed a high GNFB, using buffered VAS, the thd was very low, the sound was good but it was missing something, it was not engaging and alive like it should be.
Few month ago, after a chat with Hugh, I've decide to re-sim my amps for a OLG of 65 db and a GNFB of 30 db... the sound are now much better.
Nelson Pass demonstrated, in a paper, that to much OLG and gain stages in a amp do create more IM thd with complex signal like musics.
Merry Christmas KT and all guys.
Bye
Gaetan
What intrigues me is that it seems that the lower the number of transistors, the higher the OLG one can afford to have. This inreases stability, phase shift, and most other specs.
BTW, I think many times we use transistors in places where just resistors would do, if used creatively. This is a direction I may be heading.
- keantoken
simple amps simply sounds better...,,,,
what if you can hear inter-modulation of very high frequencies...what does eg....40 and 42 KHz sine waves create in superposition...or 100 and 110 KHz....wavepatterns with much much lower frequency content.....Does it ever stop....???
merry X-mas
If I remember right there was one paper that described an experiment where people's brains were scanned while listening and it showed more brain activity when sound <20KHz were present. Unfortunately I lost the bookmark.
Not that any source can reproduce that, but there's nothing wrong with having support for the feature...
Bigun, did you ever get that simulation working?
- keantoken
Did you mean >20Khz?
Not many well designed amps that can't reproduce up to and above ~100khz. I have squarewave tests on my Patchwork amp up that high (and higher). Real tests, not simulated. See HERE.
Stability and reliability is more important to me than bandwidth. Immunity to capacitive and inductive loads is more important also.
