Pass DIY Addict
Joined 2000
Great work! Now sit back with a bottle of wine and enjoy!
Thanks, Eric!
Holly moly, nice work!
why is the power switch only for the strobe and not the complete tt circuit?
Because I switch on and off the tt with the switch of the the psu unit
Is there a problem wiring the power switch to the secondary of the transformer so that it operates like the original?
Hi, i don't think it is a problem. I did it this way (original power switch to switch the secondarys of the Meanwell SMPS). That means SMPS is always on (it goes to 0.5W standby mode). Works flawless since 18 months.
The datasheet says lifetime of this smps depends on temperature of the electrolytic caps. If we guesstimate a maximum PSU temperature of 50°C the smps might survive 10 - 30 years when plugged in 24/7/365.
Hi All!
Here's another mod on an earlier 1210 (1989, the first was a 2004 one) that has a different main board, so it probably would interest you...
The changes are the same but original snubber caps are placed under the board and the first cap and diode bridge differ from later version.
Cheers![cheers :cheers: :cheers:](https://files.diyaudio.com/forums/images/smilies/cheers.gif)
Cheers
Peppennino- that is wonderful!! Well done!Fantastic choice of mat and feet.
mkane - Yes. This is an incredible mod. Makes an enormous positive change.
After I get the Aleph J running
I used a 10nF cap to ground the cabinet.
Looking good! Where did you find the PCB?
- Analogue Source
- Technics SL-1200 DC Power Supply
