template
any ideas where one can get a measured diagram of the adaptor(template) for the TAD 4001 horn?
Tad horns
hey diycoax, Would you be into building a pair of TH-4001 Horns? If so email me ,I am very interested in them. I have the TD-4001 drivers and and want to use them but I have had a hard time finding a set of horns.
-Collin
dupuispro@gmail.com
-Collin
dupuispro@gmail.com
Very nice horn there!I have just made a radial horn out of pine.I wont post pics as this is your thread(Pics are in system pictures).Happy horn building!
Hi, diycoax
I am very interested in buying a pair of 2" horns, if you go on building some.
I live in France.
Is it possible?
Diafan
I live in France.
Is it possible?
Diafan
Actually, from the woodworking point of view it’s not that hard to make. Granted that I have a shop and a 5hp 220v 3ph shaper. The expensive part would be a custom made knife for a shaper head. Due to the out rich of this knife it would be done on the specific type of shaper head that is if I am not mistaken called Colete head (I do have it just don’t remember the name). Then a couple of templates would give the external radius.
I am not at all saying that the work is not good, it’s just not impossible to do and other Diyers that are crazy about horns could have it done.
R-Carpenter said:Actually, from the woodworking point of view it’s not that hard to make. Granted that I have a shop and a 5hp 220v 3ph shaper. The expensive part would be a custom made knife for a shaper head.
Beautiful work.
My guess is that it's turned (on a lathe), not cut with a shaper. Yielding 3 (maybe only 2) sections from a blank.
See if you can find Yuichi Arai's old webpage as that had a lot of useful photo's and tips for building these. Mine were made by a LOT of hand sanding.MJL21193 said:
Beautiful work.
MJL21193 said:
Beautiful work.
Could be. You would need one hell of a lathe thou. I think it would need something like a 30-inch diameter capability. I’ve see a lathe like this sold a while ago on US military auction.
http://www.vegawoodworking.com/laa.html
1446 is the one I have. It’s a heavy duty one and weights a lot. It’s limited to 23 on the paper so you could do 24-25inches. It would be a bit scary, spinning a heavy piece like this. All thou a laminated Baltic birch plywood, would insure uniformity in the spinning mass. I think a template would insure consistency of a shape.
I will repeat MJL and advise anyone from using a cheap home center lathe.
I made mine By hand with an electric planer,Block plane And a sander 🙂 I dont have a workshop or i would be going mad on designs.R-Carpenter said:Actually, from the woodworking point of view it’s not that hard to make. Granted that I have a shop and a 5hp 220v 3ph shaper. The expensive part would be a custom made knife for a shaper head. Due to the out rich of this knife it would be done on the specific type of shaper head that is if I am not mistaken called Colete head (I do have it just don’t remember the name). Then a couple of templates would give the external radius.
You’d be building thing for the customers and wishing you had time for mad designs.
Teak Burma TH-4001 Horn...
Diycoax,
Are you intending to make and sell these horns? If so l am looking to purchase a pair for my TAD project. if not, l would appreciate and tips on where l could source some 4001 horns.
Thanks all,
Mondie
Thanks all,
Mondie
whatever1 said:could I get some information on these horns ? I checked and the build pictures are not showing
You can visit this webside.
Wooden Horn
- TAD TH4001 clone project
