15 inch ambiance FR
Here is my latest speaker project. Took me quite some time! Love their effortless 3d sound. The 15 inch woofer is only there for the low midrange. To crossover from the lazy 12 inch powered subwoofer to the PHY-HP FR (unfiltered).
Hey Acurus are those Olson /Nagaoka Kongo manifolds you want to build similar to the Sachiko's shown in this photo of my Sachiko speakers in the audio room?
I'm listening to: Inside Out by The Connection
Thetubeguy1954 (Tom Scata)
Sorry for late reply ,Thetubeguy1954. It's basically what chrisb said.
Cheers !
Thanx, in the area of 96 db I reckon...it easily goes beyond 110 db 10 feet away
Do you mind if I ask what make & model the woofers and ribbon is?
I'm listening to: Club de Sol by David Chesky
Thanks.
In the beginning of this project I set my requirements as follows:
• Active subwoofers 12 inch as low as possible FS
• Fullrange low-mid-high as possible but wanted linearity (used Lowther before which are too upfront)
• Supertweeter support
• Lots of dynamics in the sound
• Alnico magnets for the most part of the spectrum
• Not too tall
• Not too wide
• Depth was OK
• Simple crossovers
Well the configuration is as follows:
• Active sub XO around 80Hz (70L Wavecor Subwoofer SW312TU01)
• JBL 2220A XO around 150Hz (16 ohms, 15 inch, alnico NOS, crossover with HQ58/15/112 15mh)
• PHY-HP 8 inch silver coil (unfiltered)
• Visaton TL16H XO around 10KHz (1.4 uF)
I wanted to have a lot of dynamic and ambiance in the low department hence the extra 15inch woofer which gives a 3D dimension to the soundstage and gives of very much power around 100Hz where the subwoofer and PHY-HP would not have enough energy (PHY-HP) or would be too slow (subwoofer with heavy cone).
The configuration I came to because of practical considerations for the width of the box. But in the end it was a gamble which I now feel turned out very well. I have no longer a need for new speakers because these have it all for me (sound staging, enough low, enough high, balanced sound)…..
• Not too tall
• Not too wide
• Depth was OK
• Simple crossovers
jev - <3
Hi derwhalfisch, what do you mean?
Wont the PHY get overloaded with low bass if it is unfiltered.
Dual Chamber Reflex
More info here: http://www.diyaudio.com/forums/full-range/252627-viva-la-vifa-curvy-cabinet-dcr-tc9fd-4.html#post3856930
At first I feared so. I put big capacitors in front (can still see them on the pictures). Than I removed them to hear the effect. The sound became much more transparant. Have no problem with lows. They hardly move. Also they are designed as real full range.Wont the PHY get overloaded with low bass if it is unfiltered.
Part way finished with a pair of jensen imperials, still have yet to put trim on them and there are a pair of yuichi a290s horns that I am finishing up. In my hurry to use them, I have connected them to the low range crossover connection from the pioneers in the photo, using the midrange and tweeters for the highs. It works pretty well at 500Hz since the original cutoff was at 600Hz.
My floorstanding three-way acoustics.
They look great open speakers all in a line have the authoritative factor. I hope mrs. is ok to finish speakers before floor. My kind of thinking too, can make trouble easy ha
My audio system
http://4.bp.blogspot.com/-vJRPUghqh...DU/s1600/Organigramme+systeme+01-02-2014b.jpg
http://2.bp.blogspot.com/-_S_6M8DeHOY/Ut9fo_7DNUI/AAAAAAAADD0/kDPtzyPSi-s/s1600/P1050307.JPG
https://plus.google.com/photos/1092...71981136945?banner=pwa&authkey=CO-B186w86asUA
http://1.bp.blogspot.com/-WqsrdNjI8Ko/UwdwrHoK2SI/AAAAAAAADJA/_vFXV7mUp_k/s1600/P1050357.JPG
http://3.bp.blogspot.com/-rdRtP-fvG4M/UqrQNfoezFI/AAAAAAAACzg/5JP_EgqDHbk/s1600/P1050219.JPG
Stéphane
Stéphane
My audio system
Stéphane
They are absolute beasts! They look awesome!
Is there any particular reason why you didn´t let the buttom kabinet go all the way to the floor. instead of placing it on those 2 large boxes?
The problem is the weight (+ / - 200kg) and dimension (width 0m72 x height 1m60 x depth 0m66) of the cabinet.
The concept is a copy of studios monitors KINOSHITA RM-8VC.
The volume of cases is the same, but a problem of handling, we have cut into 2 pieces.
The horn is a clone of the model TAD TH4001.
The JBL 2450J-1 are the models used by MEYER SOUND, they were up with D16R2450.
The speakers DAVIS ACOUSTICS, a French manufacturer of loudspeakers in 30 years, it uses carbon membranes and for mounting with double ferrite.
This set was manufactured by FD AUDIO.
Stéphane
Stéphane
- System Pictures & Description
