My ProAC Clones
My first venture into the DIY arena. My ProAC 2.5 clones with a mahogany veneer.
Dan
Dan
Yes,
Nice cabinets and might I say an excellent choice in tiles you have also.😀 Same over here!
Cal
Cal
I though I would post a picture of my crappy setup, just to make everyone elses look even better. 😀
[Edit]: Yes, the prototype amp on the left speaker is powering the sub. 😀
Hi to all,
here is my setup:
Dieter
here is my setup:
Dieter
Hi Variac,
what do you want to know?
The horn is not diy, it is a JBL 2360 with TAD 4002.
The bass are 2 JBL 2226.
The UHF is a JBL 077 slot.
Crossover is diy.
Dieter
Crossover is diy.
Dieter
Technics Triple Thunder
Well here is a pic of my Existing system as it stands
- this big cat drives 70 Speaker cabinets & 2 subwoofer enclosures around the 6.5kW total RMS, holds 560 cds
linked to video etc THX pro logic
big system - has sound you can feel
Joined 2002
Id have to say thumbs down to much stuff to clutterd and humm where is the power button.. also way to many speakers.. for what reason i have no idea..
Look at his website... it makes one helluva racket no doubt!!jewilson said:
What does it all do....
Yes! all that stuff is connected,
moreso it can be all driven by Remote! the Technics SA-TX50 THX pro logic reciever is the master controller for this system - (including relay drive for the main power) it all started with 1 Technics SU-V4X running a pair of energy pro 22 spkrs, later on in time i was lucky enough to acquire a 2nd V4X and tried hookinh that too up to the existing setup with a bose AM-5 system and the result was awesome! - one night though i copped a direct lightning hit which destroyed every electrical appliance in my house - none of which bothered me except my 2 V4X amps 🙁 - with the ICs discontinued i started looking around for more amps and picked up quite alot of good models along the way, added them to a new system and when i came across another good amp, id tack that on too.... ant the result is in the pic - (well scary thing id i have more components in my spare room than i do in that system - a space limitation, those amps are assigned into the 6 channels to drive 1-2 pairs of spkrs each - some focus on higher freqs and some on lower - the basic thing being to cover the entire freq spectrum and it does just that
i have had ppl look at it and say that cant sound that good being so crammed in but when they hear it its another story,
some of the key amps are SU-V8,SU-V8X,SU-V9, SE-M100 on the front grid SU-V4X SU-V6 on surround SE-A3MK2 on the Subwoofers and SE-A7 on centre - theres alot more in there but id be on all night going through it all
- Baily
- Baily
- System Pictures & Description
