Symphony Amplifier
back to The Leach Amp
ok, here is my vision of the correction of this amplifier.
P.S. the initial current of each pair of output transistors is 110 mA.
Bonsai said:
See pages 19-23 in the link below. Although this mainly concerns itself with small signal buffers, the theory applies to power buffer stages as well, and especially in the case of EF2/3 and CFP.
https://worldradiohistory.com/UK/Wireless-World/00s/Electronics-World-2003-10-S-OCR.pdf
The article is describing a known weakness of emitter followers: they are bidirectional. Some output gets fed back to the input.
You, me, and Rotel all fixed the Leach amp in similar ways.
Ed
This amplifier is holographic and can create immense sound stage, sometimes requiring 10-20feet of listening space from speaker. It easily separates music that has space from music that has no space, pianos are life like, voices life like, flutes too real, cymbals believable , creates a live in studio experience. The prototype is biased at 130mA per C5200 WITH mje15032 used this instead of Darlington's, but you still need 100ohm base stopper resistors, using aluminum instead of servo.Dc offset 30mV
The proto type had the first break in phase within 72 hours (who knows what really happens), the next phase will be within a couple of days. Its so smooth when listening to hi res music am not yet tempted to replace the aluminums in the feedback path with the servo or film. The amplifier simply disappeared and what was left were the recordings. The foundation to a good musical experience is the amplifier, then the speaker and room and finally the source in that order. Am I missing the arc welding output stage of SYMEF, not really.
