• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
SylphAudio New DIY Modules
FB-Ultra layout (4 layer board):
Capacitor style plate layout for the opamps like on THS4222EVM.
Also avoided putting ground planes on inverting pins of the opamp / amp.
Input ground references opamp supply ground (in my BTL o/p design).
Attached docs for guidelines that I've used in designing the layout.
I'm probably going to order your FB100 but wondering when you expect to have the SE to diff preamp modules available?
around 3-6months, fixed 12dB gain, can have a volume potentiometer on its input to adjust gain.
is there an audible difference in the fb360 vs d400?
haven’t tried to listen to them side by side. I think clarity-wise not much difference.
-Lester
Reactions: 312elements
How does the FB100 do with loads down to ~2.5 ohms?
Also, is there any possibility to order the FB100 with non-standard gain? I'm interested in possibility of setting up an FB100-based amp but with gain matching my Buckeye NC252MP which has 26 dB voltage gain (balanced input only).
It can handle it but only for a certain volume level / output power.
I think no because we have to replace a lot of 0603 SMT caps to do it.
