FB-Ultra layout (4 layer board):
Capacitor style plate layout for the opamps like on THS4222EVM.
Also avoided putting ground planes on inverting pins of the opamp / amp.
Input ground references opamp supply ground (in my BTL o/p design).
Attached docs for guidelines that I've used in designing the layout.
Has anyone ever added VU meters to one of your amps? Is there a kit that would be easy to integrate?
Kind Regards,
Mark
Kind Regards,
Mark
Hmm no idea if anyone added a VU meter before.Has anyone ever added VU meters to one of your amps? Is there a kit that would be easy to integrate?
It needs 7.3Vrms balanced input. Gain is 10dB or 3.16V/V. Max output is 23VrmsDoes the FB Ultra Need 10-12 Volt preamplifier?
FB100 and FB360 requires 4Vrms balanced input.what about FB360?
Latest budget DACs like DL200 have 5Vrms outputs already.
Though we will release a budget SE to Differential preamp module to complement the FB series.
FB-Ultra prototype after all the testing lol. Sings beautifully, no click/pop on power on/off.
Needs multiple rounds of PCB prototyping for layout and parts optimization. ETA 6 months.
Sami,
I'm probably going to order your FB100 but wondering when you expect to have the SE to diff preamp modules available?
around 3-6months, fixed 12dB gain, can have a volume potentiometer on its input to adjust gain.I'm probably going to order your FB100 but wondering when you expect to have the SE to diff preamp modules available?
haven’t tried to listen to them side by side. I think clarity-wise not much difference.is there an audible difference in the fb360 vs d400?
-Lester
FB-Ultra has taken its shape.
130mm * 65mm, output coils on yellow squares
Fully differential mono design. Max 130W @4ohm
Power Supply: ±21V DC
UVP: ±18V, OVP: ±25V
New price estimate around 282 USD per module.
Any update on this?
Hi, development for FB-Ultra has been put on hold indefinitely.Any update on this?
How does the FB100 do with loads down to ~2.5 ohms?
Also, is there any possibility to order the FB100 with non-standard gain? I'm interested in possibility of setting up an FB100-based amp but with gain matching my Buckeye NC252MP which has 26 dB voltage gain (balanced input only).
It can handle it but only for a certain volume level / output power.How does the FB100 do with loads down to ~2.5 ohms?
I think no because we have to replace a lot of 0603 SMT caps to do it.Also, is there any possibility to order the FB100 with non-standard gain? I'm interested in possibility of setting up an FB100-based amp but with gain matching my Buckeye NC252MP which has 26 dB voltage gain (balanced input only).
I re-voiced the FB100, it now comes with Black Elna Silmic II input caps.
Also replacing the VDD chip inductor with 0 ohm resistor greatly improved the highs. (Only applicable to FB100 and FB360)
I checked the LTSpice sim, maybe 20dB gain can be done with four SMT resistor changes with slight roll-off at 20kHz.I think no because we have to replace a lot of 0603 SMT caps to do it.
Already checked, FB360 has "finer" highs.haven’t tried to listen to them side by side. I think clarity-wise not much difference.
I've put it back since the module's sound became sensitive with lower quality SMPS. Means the highs became worse if the supply that's being used is not good.Also replacing the VDD chip inductor with 0 ohm resistor greatly improved the highs.
Latest 5W, 4 ohm measurements for a "random" FB100 module.
The FB100 page now reads:
Update: Feb. 2025
Changed input caps, all OPA1612 preamp
An FB100 board shipped middle of January would still be the old version, whereas ordering now would get the new version?
Update: Feb. 2025
We only sent the boards with all OPA1612 in the last week of January.An FB100 board shipped middle of January would still be the old version, whereas ordering now would get the new version?
Before that, it was OPA1612 + OPA1602.
SE800 PFFB is already available!
Here's the 5W 4Ω FFT with the highest rail supply (+/-85V) and 26dB gain.
We'll get better THD+N if we lower the gain to 22dB (through resistor change).
5W 4ohm SINAD already better than a non-PFFB TPA3255.
Sound is bass heavy, and the highs are good. Really a step up from High-density Pro-Amps
- Vendor's Bazaar
- SylphAudio New DIY Modules
