Andrew, unfortunately that LED is now obsolete, but Mouser recommends 941-C566CRFECV0W0BB2 as a replacement. I think that works as a direct drop in replacement.
BC847C Unavailability
Hi Bonsai,
please don't ask me how slowly I'm building the Ovation-nx.
Actual picture
I have just discovered that the BC847A I have ordered to Mouser has the wrong package and doesn't fit into the PCB.
Unfortunalely the 771-BC847CT115 is obsolete.
What can I use instead of it?
Hi Bonsai,
Actual picture
BC847CT-7FDICT-ND in stock at DigiKey. Mouser is out of stock on this one. Before ordering do carefully check the datasheets to be sure the package is what you want.
Thanks,
I need to order on Mouser. I have other things to order, so that I can avoid the shipping costs.
My problem is that I don't understand what is the appropriate package.
SOT323 seems appropriate, while SOT23 looks too large.
The original 771-BC847CT115 is declared to have SOT-416-3.
However in the specs (https://www.mouser.it/datasheet/2/916/BC847_SER-1598765.pdf) I don't see the BC847CT.
On Digikey the BC847CT https://www.diodes.com/assets/Datasheets/ds30274.pdf is declared to have SOT523 (that measures well on the PCB).
I'm quite lost!
I'm quite lost!
Here is how I see it.
SOT416 and SOT523 are essentially identical and should both fit the PC board.
SOT323 is a bit larger but might still fit the board. You would be taking a chance if you order this one.
SOT23 is too big.
SOT23 is too big.
Ok, let me go with 863-BC847CWT1G (https://www.mouser.it/ProductDetail/onsemi/BC847CWT1G?qs=vNc2DXHODiIUboPgW9W%2FPw%3D%3D)
In the specs (https://www.mouser.it/datasheet/2/308/1/BC846AWT1_D-2310458.pdf) I read: SC−70 (SOT−323).
I hope for the best.
Thanks again.
Thanks again.
Hello,
The part should be a standard BC847 in SOT23 (not the other packages). Mouser are showing about 8000 in stock.
https://www.mouser.co.uk/datasheet/2/916/BC847_SER-1598765.pdf
Thank you,
the problem is that the "C" version is not available.
"B" (or "A") version are valid alternatives?
BC847 nexperia Single SOT-23-3 Bipolar Transistors - BJT
Hello,
Your document The-Ovation-nx-Amplifier-V2.0_9.pdf shows the transistor as 771-BC847CT115. This is package type SOT416, smaller than the SOT23. In post 2386 sx-Amp and nx-Amp the excel bom also lists BC847CT115. I built my unit with this part number but don't recall how the fit was to the board.
Scaling an image of the board, the layout appears to actually be for the SOT23.
Maybe the BOM just needs updated.
Bill, I think you are right - looks like an error on my part. Thanks for catching this.
It is supposed to be a SOT23 device.
(I probably need to redo the BOM anyway as it’s 9 yrs old now 2012 was when the nx and sx first came out. They’re still selling through Jim’s Audio. I think in total with the V1 and V2 boards he sold about 350)
Thank you,
Yes you can use A or B
Mouser has SOT23 BC847C transistors in stock from several vendors.
621-BC847C-7-F Diodes Incorporated 3,806 In Stock, $0.20 each
863-BC847CLT3G onsemi 97 In Stock, $0.16 each
621-BC847C-13-F Diodes Incorporated 1,098 In Stock, $0.20 each
726-BC847CE6327 Infineon Technologies 13,546 In Stock, $0.22 each
It appears that the 2N7002 (Q3) on the power supply is called out as a SOT323 instead of a SOT23.
771-2N7002PW-115 SOT323 Q3 on power supply bom
Mouser has SOT23 packages:
771-2N7002NXAKR Nexperia 618,494 In Stock, $0.19 each
512-2N7002L onsemi / Fairchild 5,051 In Stock, $0.28 each
757-T2N7002BKLM Toshiba 9,091In Stock, $0.17 each
I checked if the 2N7002, which is a SOT-23, fits in the amplifier PCB.
Yes! So, I'm ordering a 771-BC847C-T/R.
Doing the final checks (and ordering the few components with the wrong measures) for the amplifiers I realised that the fuse holders I have do not fit the PCB.
I'm unable to find any suitable fuse holder (the 504-HTC-201M is out of stock in Mouser -and not only).
Any suggestion?
Amplifier Image
Any suggestion?
Amplifier Image
I'll do some work on the BOM this week end. Tyhese amps still have a lot of life in them despite going on for nearly 10 yrs old.
What can be better? Those amplifiers have a still modern architecture, and, to my knowledge and in my simulations, they conjugate simplicity with performances.I'll do some work on the BOM this week end. Tyhese amps still have a lot of life in them despite going on for nearly 10 yrs old.
The only thing I hated are the SMD diodes in the PSU. I could find the cathodes only using a microscope.
And hoping for the best:
More: one of them is so small that I'm no more able to find it in my workbench. Lost! and to reorder 🙄.
Let me ask the N-th question: the BAS21H are impossible to find. Next builder will have difficulties.
BAS21J is a bit smaller than BAS21H but should still be usable on the board. Might have to do a slight solder bridge to get it connected. Mouser part number 771-BAS21J115. Always order more tiny SMD parts than you need since it is easy to lose them and they are usually cheap.
This would help all the people wanting to build that PSU (mine is quite complete, apart that diode that is somewhere!).BAS21J is a bit smaller than BAS21H but should still be usable on the board. Might have to do a slight solder bridge to get it connected. Mouser part number 771-BAS21J115. Always order more tiny SMD parts than you need since it is easy to lose them and they are usually cheap.
I checked the size of the BAS21J and it will be solderable on the PCB without any bridge.
- SX-Amp and NX-Amp
