SX-Amp and NX-Amp
Platon, ok - try the following:-
1. Connect the cathode of D17 to 0V
2. D15 should go OFF
3. If it does not go OFF, measure the voltage at the drain of Q3 with D17 still shorted to 0V
4. The voltage should be near to V+. If it is near to 0V, then it is likely that Q3 is faulty.
5. If the drain voltage is near V+ with D17 shorted, then U1 is probably faulty.
I suggest you just replace Q3 and U1
(Your gate voltage is a bit low - either your meter is loading it, or you have some gate leakage which is a sure sign it is faulty)
I have Service manual "Update November 2014 v 2.09"
There is U1-PDTA144ET PNP 10k.The datasheet NXP is PDTA144ET PNP 47k!!!! No 10k.Resource settings writing U1-47k.
Please include the correct values U-1 and U2
D17 acts primarily to ensure the max voltage across the gate of th the mosfet is 4.7 V. This is to ensure that the turn off time is reasonably short. The2N7002 will be on well below 4.7 Volts.
Did you do the specific tests I proposed in post#1701, Platon? You have to isolate where the problem is from.
U1 was changed to 47k to reduce the dissipation. This is not the root cause of your problem.
Either the issue is coming before the 2N7002, it's with the 2N7002, or its U1 or any combination of the above. Please do the specific tests in post #1701
hello, i am a beginner in the diy world ,i never built an discrete amplifier, chips -yes and i was about to buy these pcb from ebay.
But it looks like these amplifiers(100Wx2 Ovation nx) are not so easy to be done, 171 pages of tweaking and questions prove that. My question would be if i should start with the 60-100watts hi fi power amplifier from sound.westhost.com rod elliott or to give the 100Wx2 Ovation nx a try?
thanks guys
