Sure Electronics Tripath boards?
Thanks for the link and your review of the board dpuopolo....
First off, it's bass GRABS you-it's MUCH tighter. This is with only a 1 uf input capacitor across the .3 already there.
This may be because the input caps on the sure boards are close to 1uf not .3uf...If I have measured right?
It amuses me the board provides terminals for MUTE and SLEEP without a 5v to connect to. Please don't connect these to VDD.
Bongoman, it is possible to link Mute to VDD, there is a 20k in series with the pin, seems to drop the voltage down to about 5volts..I have tried it and it mutes...The Sleep is a different matter..
One minor complaint is that at times it can sound a bit saturated at the top end, with certain trebles turning into more of a hiss.
I wonder if you have reached the limit of the inductors?
Finished the Headphone amp, does the job. No idea how good it is, have neither the good headphones or another good headphone output to compare it to, it is revealing tho..😱
Does the latest versions still have 100nF as C3 and C24? That would create some serious lowpass with a volume pot indeed 😀. Weird, since the schematic on manual seems to have 100pF. Are even the C13 and C21 2.2uF as in schema?
I don't think that's it, because I used a 10 uf electrolytic cap bypassed with a 1 uf film in the Sonic Impact amplifer. That means its 3 db point is at: 1.4 Hz.
dpuopolo. I read some time ago that the Tripath amps were not good for headphone amps because of some ultrasonics (or something like that ) that could damage your hearing ? Panomaniac posted about this in one to the S.I modding posts.
I'll see if I can find it.
Very noob questions
OK guys, time to check you patience meters. I've got some real n00b questions.
I just got my first soldering station and it's burning a hole in my pocket(not literally 🙂 )and I want to try my hand at modding this board. I figure I'm only out $20 if I fry it, so why not try?
Question #1. Where is a good place to tap for a "on" led? Voltage in(with appropriate R)? Am I right in thinking that VDD outputs 12v? Could I do the same here?
Question #2. The tank cap option. What are the pros? More headroom? At what value would one expect to start to hear improvements? Is there a sweet spot?
Ok, that's more than two questions, but I'm eager to learn.
Great thread guys. I've been curious about this board for a few weeks now. I shoulda know to look here first.
Update of Mods so far:
C21 & C13 replaced with 2.2uf Epcos MKT.
C3 & C24 removed.
R3 & R16 replaced with 1M ohms.
R1 & R18 replaced with 15k in series with 10k trimmers for DC offset adjustment.
R8 & R14 replaced with 26k7 0.1% 15PPM resistors.
R7 & R13 replaced with 31k6 0.1% 15PPM resistors.
D1 removed and bridged.
2 Panasonic FM 330uf 35V added near chip.
2 Panasonic FC 2200uf 16V added on rails.
Has anyone tried bypassing C3 & C24 with .01ʯf -.02ʯf as a high pass filter?
(.01ʯf soldered in parallel to C3 & C24)
Re: Very noob questions
Hello, The voltage at both VDD terminals will be the same as the voltage you supply to the board. So a LED in series with about 1k resistor between VDD and GND will be OK.
The tank cap is there to improve the bass, a value of up to 10,000uf won't do any harm, if there is a best value you will just have to try different values and combinations and see what works for you. I just use what I have and hope for the best...
TheSeekerr said:
Well, I've ordered a replacement for the board I killed - can anyone give an indication of expected shipping time from experience? I'm hoping my last one wasn't indicative, since it was over the christmas/new year period.
mine arrived after about 3 wks after the winning bid in ebay. I will be modifying it slowly, just a newbie and will follow the mods recommended here.
gychang
Had a chance to do some listening on my test bench (Hrrmm, Cough) For test bench read Workmate in garage with old Mission's and NAD 3020 as a pre-amp.
It doesn't really like 12v does it. No wonder they revised the later versions to 9-14v. I am using a 13.8v at the moment and have got reasonable volume. I have read that 16v is possible and so I will make a PS at 16v. However in main system I only need about 1Watt.
It sounds pretty good. So some running in and 16v should see it alright.
Replaced R8 and R14 with 10k resistors. Great call guys! That helps out alot for lower volume songs. I impressed myself being able to solder such a small area. All the advice helped greatly.
If I wanted to get crazy, at get more gain what resistor value would I use?
Mike
