Super Regulator
Confession: I am not an EE, and I my math SAT score kept me out of Harvard. I am a lawyer, not a doctor.
Still, I am either fearless or foolish and I am learning the language of electronics for the first time to build the pre-amps and power supplies and amps etc of my dreams. I need some help with translation and finding alternative parts for things I can’t seem to find on Digikey or Mauser. I am banking on that my fumbling around will bring you all back 20 or 30 years to your memories of getting started enough that you will have patience with me. Also: I am old enough that my kids are leaving home and have some extra time. If there is a good key somewhere for these terms that doesnt require me to take a couple years worth of PHD work in EE, I would love to read it.
From the Super-regulator BOM:
I. Ics
The spot on the schematic is U1-U2. I understand that much.
Category: Ics What does this mean?
Values: AD825 or AD817 I'm having trouble finding these available. Recommended alternative?
Description: DIL-08 or SOIC what does this mean?
II. Diodes
For the Diodes, I spent an hour or so looking for the parts on the two ordinary vendors, but I am not sure I was able to understand the terminology well enough to search for them properly.
I understand the locations they will go. D1-D10.
D1,D6 The 2 LEDs
Value = LED. ß I know what that is, and I understand the pitch spec. The general statement of LED isn’t much to discriminate between the many available ones, so I am not sure what to choose from, or how to find them in vendor search tools. You probably all have regular sources for these, but again, I am just not there yet. Any word here?
D2,D7
Value: Z6.8 This value isn’t enough for me to find anything in the searches. What does this mean?
Description: 0.25W if I can find some Z6.8s, I am guessing I know what this means.
D3-D4, D8-D9
Value: 1N4148 Ok. This was enough to find several examples. But there are, of course a variety of spec choices, and I don’t know enough yet to tell if the differences will matter, or why.
Here are a few choices, for example:
Onsemi --- General purpose, 100V, 200MA, DO35
SMC Solutions -- General purpose, 75V, 300MA, DO35
NTE electronics -- General purpose, 75V, 150MA, DO35
OK. What are you guys thinking about when you see these voltage and amp differences. Do they matter for a diode need in our use here? If not, why?
And what does the DO35 mean?
Any quality opinions on the manufacturers that I ought to put in the back of my head?
D5, D10
Value: LM329
Description: T0-92
Ok. This was a doozy. There are several different types of components that come up when you search this value.
First, I found a bunch of things that look like transistors to me, not diodes. Like this: https://www.digikey.com/en/products/detail/analog-devices-inc/LM329CZ-PBF/962323
Happy to order them, but again, they appear to be transistors and so I hesitate. If these ARE the right things, how do you guys distinguish between them and know that they will work in this board need?
There are CZ and AZ options. I have no understanding of the differences or if they are important for the voodoo.
Then, there are some “RF modulators”. I am assuming – from the RF label -- these have nothing to do with us. Is that right?
Some other components came up as well.
IV. MISC
Heatsinks: I don’t see the heatsinks needed for the superregulator identified in the BOM.
Am I reading it wrong? Suggestions?
Terminal Blocks
J1,J5
Values: TBLOCK-I2
Desc: 2-pin screw terminal 0.2” pitch
J1,J6
Values: TBLOCK-I4
Desc: 4-pin screw terminal 0.2” pitch
I am sure that most of you know what this all means immediately, but imagine you are me for a second, If you search for these values in Digikey, nothing appears. So I look at the terminal blocks in general, try to use the description to shun the ones that won’t fit, etc. Several options appear. For the uninitiated, it is impossible to tell if they will work, and more importantly, WHY.
For example, the search wizard characteristics include:
Current, voltage, orientation, Mounting type, Wire termination.
I can stab at it, but I know I will screw this up.
My questions: How do you guys tell the differences?
Are there better ways to find the 2 and 4 pin blocks that are spec’d on the BOM? Search terms?
Thought bubble: “MAN THIS GUY IS REALLY AN IDIOT”
Yeah, pretty much.
OK that is all the questions I have for now. Any patience with me is much appreciated as I try to learn your peculiar language.
Bonesthrower - Gary
Lincoln, Nebraska
90% of these can be found with a simple google search. Most of the parts were found easily through Mouser. The LED's were specified as green LED's in the reading, I know its a lot and the heatsinks are "Fischer sk104, 35mmx12.7mm, with a 25.4mm spacing for the solder pins". I just found this by searching for heatsinks and looking through 5 pages of results. I don't think they are available in the US. Terminal blocks, you might want to ask, they are a problem to find the right ones. I had some on hand that fit.
Hi Bonesthrower (can't help but think there is a story there somewhere...)
Many people on this forum start where you are at - me included, I am still an idiot, but over time some knowledge sticks.
I don't know of any comprehensive primer that will fit your needs, but here are a few suggestions:
As RickRay said, a search engine is your friend, e.g.
ics - integrated circuit, where the manufacturer fabricates sometimes complex devices on a tiny silicon wafer and packages it in a usable form.
DO-35, TO-92 - JEDEC specifications for device form factors, look on wikipedia.
TBLOCK, 0.2" pitch - terminal block where the pins are 0.2 inches apart; the terminal block is attached to the pcb to create a safe and secure connection for external wires
You have a wonderful learning journey in front of you. Take the time to enjoy it.
Reactions: NORTH4
@jan.diddan - I was able to test the negative rail output with a different oscilloscope with the ground power lead disconnected. I have the same issue. I have attached a picture of the scope screen.
Anyone else have input on this issue? I'm guessing this is a 54kHz oscillation. It is across the load and across the input. The input is a bench power supply, Rigol DP832. I checked the output of the Rigol without the SR connected and it is rock solid no noise on the output.
OK, I commented that because some time ago, just for fun, I tried the LF411 FET opamp, which is not a low noise chip, and simulated it in LTSpice. If anyone has used LTS I would ask you to try. The impedance curve I got, for +/-30 and +/-15v is one of the best, certainly better than the AD825 and AD817. Same thing with the LT1115. Neither of them is even mentioned by anyone.
As Jan said, when I uploaded my asc file, that some components I used were not available on every LTS, so I just ask: can anyone simulate those chips on their own superregulator simulation? And then comment on what are the results?
The following was made to set 24v
D5 change from LM329 to LM4040-10
24V - 10V = 14v
14/10 = "Z"= 1.4
"Z" multiplied by R7 or R14 value = R6/R13 value
for
R7/R14 = 1K
R6/R13 = 1.4K
D2(pos) and D7(neg): change the zener from 6.8v to a 12volt
but I am getting about 24.8v
Good morning sorry for the inconvenience but I would like to ask you for some info considering that I'm a rookie and I don't want to make a mistake!!
When you say...
D5 change from LM329 to LM4040-10, is it necessary to replace only D5 or also D10?
Thank you
Giampiero
Analog Devices' ADA4523 will give you very low output impedance.
Good evening and sorry for the inconvenience, I am writing to you since you are online at the moment and since I still haven't been able to get the information I needed, I take the liberty of asking you. I take a comment that I found on the forum and ask the question.
The post: The following was made to set 24v
24V - 10V = 14v
14/10 = "Z" = 1.4
for
R7/R14 = 1K
R6/R13 = 1.4K
D2(pos) and D7(neg): change the zener from 6.8v to a 12volt.....
Question: When you say...
Thank you so much
NB: I know it has nothing to do with his position and I don't know if I'm doing it right but I'll insert it here ..
MY SR was set for 20V and I changed both D2, D7 and D5, D10 to 10V. Yes, D5 and D10 need to be the same, whatever they are. One is for positive rail, the other is for negative rail. You could safely use 12 volt in all 4 positions, it's half your output voltage.
Why use LM4040-10 when it is much worse than LM329, with resistors 1720/705 you get 24V or 1430/768 for 20V and with LM329 which has lower noise and lower dynamic impedance than LM4040.
In my 4A versions for Le Monstre I use an improved low noise LM329 and 1370/787 resistors for +/-19V.
Perché usare LM4040-10 quando è molto peggio di LM329, con resistori 1720/705 ottieni 24 V o 1430/768 per 20 V e con LM329 che ha un rumore inferiore e un'impedenza dinamica inferiore rispetto a LM4040.
Nelle mie versioni 4A per Le Monstre utilizzo un LM329 a basso rumore migliorato e resistenze 1370/787 per +/-19V.
Buongiorno, ok perfetto, ho capito.
solo una domanda, a cosa ti riferisci quando dici .."con resistenze 1720/705..." quali sono i valori? scusa ma sono solo un principiante...
Grazie mille per l'aiuto
:cop: please post in English. Rules!
Good morning, ok perfect, I understand.
Just a question, what are you referring to when you say.." with resistors 1720/705..." What are the values? sorry but I'm just a beginner...
Thank you very much for your help
just one question, what are you referring to when you say .."with 1720/705 resistors..." what are the values? sorry but i'm just a rookie...
thanks a lot for the help🙄
