Jan,
my Fluke multimeter shows 24.78v on the outputs.
>>you can measure the nominal 10V of the ref, see what that shows.
I'm getting 9.95vdc on legs of D5
It seems then that the resistor divider is not exact. The only other possibility I can think of is that the zener in the opamp output is the wrong way around.
Is the voltage at the opamp inputs the same?
Jan
Jan
It seems to me, that VoltRef does not appreciate too much bias current
What does this mean?
Jan
that the noise figure of voltage reference gets worse with higher current.
I am no expert, by no means. If more experienced people say, that LM329 likes it more at 3mA than at 1,1mA, i will swap present 8,2k to 4,7k that i have at hand in no time.
More important question is, whether the CCS feeding the pass transistor and opamp is at all essential, i.e. can i swap a npn pass transistor for pnp type for positive rail, and sink the current from pnp`s base directly with op amp?
You can forget about noise since the opamp is the main contributor. The voltage reference’s noise is filtered away in the lowpass filter.
then, as long as i keep the current in LM329 above the regulation knee at 660uA, and below it`s maximal rating, it doesn`t really matter if i use the original 4,99 k, my 8,2k, or 4,7k at hand ?
does the impedance curve of the 100uF electrolytic capacitor around zener diode between opamp and pass transistor`s base impacts the regulator`s output impedance ? Wouldn`t it be worth it to try there some low impedance MLCC cap ?
Jan,
In response to your post #2382.
I triple checked all diodes orientation. Maybe resistor divider is not exact (I hope).
With 27Vdc on inputs I took the voltages on opamp (in reference to Ground) and the result is as follows:
pin 2 (-in): 9.95v
pin 3 (+in): 9.95v
pin 6 (out): 13.15v
pin 7 (+Vs): 24.79v
I am trying to get 24v out of the regulator. Do you see if there is an issue?
Thanks!
pin 2 (-in): 9.95v
pin 3 (+in): 9.95v
pin 6 (out): 13.15v
pin 7 (+Vs): 24.79v
Thanks!
Pin 2 and 3 has exactly the same voltahe so this means that you have regulation. Your reference voltage is 9.95 V but which resistor values have you chosen? Resistor tolerance?
I agree. The regulator works fine.
You measure 24.79 on pin 7 - that is Vout. If it is not exact 24V, check the feedback resistor value.
Or read my 1-page writeup at diyaudio store.
Jan
Jan
The following was made to set 24v
D5 change from LM329 to LM4040-10
24V - 10V = 14v
14/10 = "Z"= 1.4
"Z" multiplied by R7 or R14 value = R6/R13 value
for
R7/R14 = 1K
R6/R13 = 1.4K
D2(pos) and D7(neg): change the zener from 6.8v to a 12volt
but I am getting about 24.8v
24V - 10V = 14v
14/10 = "Z"= 1.4
for
R7/R14 = 1K
R6/R13 = 1.4K
Make the most accurate measurement you can of the resistors that are used in the divider. Do not discard any digits. Take those most accurate measurements and calculate the divider ratio.
For example, if you measure your 1K resistor does it measure 1.04k or does it measure 1.003k? Is it a quality 1% resistor? Is it a 5% resistor? Are they Ebay resistors?
What about the 1.4k resistor? What does that measure?
What meter are you using? What is the resolution and the accuracy quoted in the manual for that meter?
Your circuit and values are fine. But they are nominal. The ref is not exactly 10V. The resistors are not exactly 1k and 1.4k. Measure them.
Also, in the original superreg there is something called remote sensing. Did you use the original board? If so, how did you connect the sense lines? What part values for the remote sense filter? For example, if you used 1k then that's it there and then.
Jan
Jan
Jan,
I used the original board. Sense lines are directly connnected to outputs, just for testing.
post#2374 has the photo.
I am sure that between the D5 and R6 and R7 being slightly off, I will be able to make ajustments to R6 and R7 to get to 24v exactly.
THANKS for the support!
Yes I'm sure you will. And I found that I forgot to mention in the writeup that the remote filter resistance, R16 in the pos reg, should be counted toward R6.
Because R16 is in series with R6, and at 100R, in your case, adds about 100mV to the output.
Thus my suggestion if you had 1k or 910R there, it would go to 24.8V.
The ref is a bit below 10V so that pulls it down a bit but only a few 100mV.
We are used to think that these circuits always go to exactly 24V but generally you can expect +/- a few 100mV and that would be inconsequential.
24.8 seems a bit high though.
Jan
Jan
Good day friends
I am setting up a Superreg Positive for +24 but only getting 13v out. Resistors calculated and zener changed to 12v. What gives?
Can you do the measurements in this post:
https://www.diyaudio.com/forums/the-diyaudio-store/247281-super-regulator-239.html#post6622799
... and let us know what you find.
{Amazed} why doesn't anybody measure anymore?? How the hell would we know if there are no measurements. Crystal Ball?
Jan
Jan
Maakt mij niet de brutale 😕
I have taken all the measurements as per the whole design and discussion yet it remains at 13vdc.
I have installed a trimpot in place of R6 to adjust it spot-on and no luck.
Tried 2K2 with 5K45 ratio and the 1K with 1K4 ratio and no luck. The Zener is a 12v unit and I have confirmed it.
On pin 2 I get 5.7 and on pin 3 I get 6.3vdc
Supply voltage is 36vdc
Load is a Pass XLmini filter board for 24vdc.
Question about LM4040 and resistance ranges R14 / 7
I have 2 questions about the Super Regulator.
Does it matter in which resistance range, the values for R14 / 7 and R13 / 6 or does that affect the function of the circuit.
E.g. for +/- 15V you could use 1K / 1.17K or 10K / 11.7k or 18k / 21.19k. There is an area that is desirable?
I wanted to order LM4040 from Mouser for other voltage ranges.
Can i take all of them? I've seen some whose VREF - Input Voltage - Max (e.g. 5V) = Output Voltage (e.g. 5V).
Shouldn't the VREF - Input Voltage - Max be higher?
LM4040AIZ-41-NOPB or LM4040AIZ-50-NOPB
- The diyAudio Store
- Super Regulator
