Hi ScottG,
Thanks for your comments.
..Zaphs profile is to build nice speakers from cheap drivers and I think that’s ok, but everything more expensive gets low value for him, despite the fact that you often actually get something more from the driver that costs more. It would really interesting to hear anyone’s impression of this woofer used in a diy build.
/Goran
Your welcome!
Actually I don't really look at his comments or his ratings.
I couldn't tell you about the lower freq. distortion performance of the Lambda 10, could be better, could be worse. I would say however that you have more excursion with higher compliance, and greater sd - which should result in better performance. As for cabinet size, the 3.5 cubic feet is a recommendation but not an absolute by any means.. basically it's all down to how low in freq. you want to go vs. power and maximum spl.
Maybe you could take a look at the Newform ribbons. They sound terrific and with their length and ablity to be adjusted up and down on the mounting pole make them very versatile. The 1000hz + crossover point allows you more options with your other drivers also...
LINESOURCE REFERENCE - Ribbon Array Ultra High End Audio Speakers for Home Theater and HiFi Music Systems
BG have also line array's that play the hole midrange usable as dipole or monopole. They will do a lot of things better then a cone driven speaker I guess, and they will also have their drawbacks I don't know because I never used them.
RD40 300-20000
RD48 250-20000
Stig Eric likes them a lot I read of his reply's.
RD40 300-20000
RD48 250-20000
I’m familiar with the Newform tweeters. I almost bought a pair for about 15 years ago. As I recall they were quite expensive and I never went through with the order.
I’m extremely found of the ScanSpeak midrange sound so I think I stick with it. The question for me right now is which woofer and tweeter to combine with the midrange. The smaller ribbon R8 could be interesting, but it's quite expensive and has a low sensitivity.
/Goran
Hi everyone,
I have begun sketching up a new 3-way floor-stander design. My wife is tired of how many different loudspeakers have in the living roomOk, I said let me build a super high-end loudspeaker that I can live with for a long time, then I promise you that I will only have one set of loudspeaker in the living room.
She said…….. Do it!
I realize that this project will take some considerable time to finish, especially since I most likely will have to design and build the enclosures by myself and they must match the drivers in build quality and looks.
There are so many different loudspeaker drivers and manufactures that can be considered as high-end, but I have so far chosen two brands of loudspeakers, ScanSpeak for mid and woofer and RAAL for the tweeter section.
Why these two brands? Ok, I just love the build quality and looks of the ScanSpeak drivers. I also have some experience with ScanSpeak drivers and I like the performance of them. Why the RAAL ribbon tweeter? What I so far have managed to research, it seems like the RAAL ribbon is the “mother” of all ribbons.I have used Fountek ribbons in several designs and I must say I favor the ribbon sound when used properly over the dome tweeter sound. I know this is a hot topic, dome vs. ribbon, but I have to follow my perception that I subjectively like ribbons more.
Since I’m unfortunately isn’t a rich man I can’t buy and test every driver I consider for this design and here is where I really need your help!
Please share any thoughts, experience and measurements you have on the listed drivers below. I cannot do these design choices without your help. Especially ScanSpeak is notorious of not measuring as published (TS-parameters).
My contribution will be a thread of my build where I will share my thoughts, measurements and the cross-over design etc.
Ok, here are my 3 different design choices so far:
Alternative 1:
Tweeter: 1x RAAL 140-15D
http://www.raalribbon.com/download/raal_140-15d.pdf
Mid: 1x ScanSpeak 15M/4531K00
http://www.scan-speak.dk/datasheet/pdf/15m-4531k00.pdf
Woofer: 2x ScanSpeak 22W/8851T00
http://www.scan-speak.dk/datasheet/pdf/22w-8851t00.pdf
Estimated cross-over frequencies: 300-500Hz & 2000-3000Hz
Estimated driver unit price/pair: 2540€
Alternative 2:
Tweeter: 1x RAAL 70-10
http://www.raalribbon.com/download/raal_70-10.pdf
Mid: 1x ScanSpeak 12M/4631G00
http://www.scan-speak.dk/datasheet/pdf/12m-4631g00.pdf
Woofer: 2x ScanSpeak 18W/8531G00
http://www.scan-speak.dk/datasheet/pdf/18w-8531g00.pdf
Estimated cross-over frequencies: 500-700Hz & 3000-4000Hz
Estimated driver unit price/pair: 1870€
Alternative 3:
Mid: 1x ScanSpeak 12MU/4731T00
http://www.scan-speak.dk/datasheet/pdf/12mu-4731t00.pdf
Woofer: 2x ScanSpeak 18WU/8741T00
http://www.scan-speak.dk/datasheet/pdf/18wu-8741t00.pdf
Or
Woofer: 2x ScanSpeak 18WU/8747T00
http://www.scan-speak.dk/datasheet/pdf/18wu-8747t00.pdf
Estimated cross-over frequencies: 400-600Hz & 3000-4000Hz
Estimated driver unit price/pair: 2250€ or 2200€
Comments:
I will first do an active version (DEQX) of the loudspeaker and later on a passive cross-over version. At this stage I have no idea of how the loudspeaker shape and design will look like, but considering the amount of drivers and size it will be a fairly large enclosure (60-80litres internal).
I want the loudspeaker to be as efficient as possible and my estimate, depending on driver choices is that it will be around 88db (+- 2db) 2.83v/1m.
My estimate of cross-over frequencies is just an estimate based on driver size and estimated distortion numbers. When the drivers are placed in an enclosure and measured properly I will know more accurately.
My estimate of the price is based on the driver units only without shipping or other fees. The prices are collected from Europe Audio - Home page (ScanSpeak) and www.loudspeakershop.eu (RAAL).
For now, I’m most interested in alternative 1, but I would greatly appreciate any information/experience you guys have on the above drivers.
Help me choose the right design.
Thank you!
/Goran
Congratulations on clearing the biggest hurdle (WAF) to your future high end build. No doubt, given your experience, methodology, and SS drivers you are going to build something really awesome. To the less experienced it would be a gamble and we would be better off building a proven design.
All the Alternatives would make great speakers, but I like "Alternative #1", because the crossover frequencies are outside the critical "telephone" passband. Have not heard the 15M, but I've heard the 15W and it is about the best mid/woof you can buy. Along with the RAAL you are at the end of the road.
If you can give a listen to some Wilson Audio or Dunlavy speakers. You may not like them overall, but they do some things really well, especially the larger ones.
I might add, if it is possible, you might try to have a separate upper bass driver dedicated to around 75Hz to 250Hz. Some may even argue that this is actually where most of the visceral energy or life of the music is. Unfortunately, this is really expensive (almost prohibitive) to do passively, but there is an effortless impact to the sound that conventional 3-ways lack. Of course, a properly designed 3-way might be all that you will ever need and is miles ahead of any 2-way.
Hi ultrakaz,
Thank you for your kind words
I have decided to scrap my alternative 2 and 3. I will stick to my alternative 1 with the 8” Scans. However, this design sketching has grown to 3 different 8” configurations with 3 different tweeter and 2 midrange options.
I was a bit curious on the Illuminator series, but I couldn’t find enough information about them to make it worthwhile to proceed on that track.
Soon I will post my new design thoughts and some box sims around the SS 8”.
/Goran
Thanks for your comments. That’s a cool and futuristic design, but I think it would be a challenge to build.
From wood yes, but what about another material (mix) and a pour in solution. Just a thought. Good luck.
Sorry - posted out of sequence.
You might consider Skaaning. Speakers are not designed by corporations, but by skilled engineers, and I consider Skaaning to be one of the most talented engineers in the field - he's the one that designed some of the best-known Scan-Speak drivers.
True, they're not cheap, but that's not surprising when you consider these are not Chinese-made drivers that mimic the look of Scandinavian drivers, but the real thing, made in Europe. I've heard speakers designed around the Skaaning drivers, and I weren't so deeply into the high-efficiency thing, those are the ones I'd choose.
RAAL makes superb ribbons, but keep in mind that even the large ribbon is at its best well above 2 kHz - 3 to 4 kHz is a better choice for the crossover point. So if your heart is set on ribbon treble, do yourself a favor and select a midrange that needs as little equalization as possible through 5 kHz, or above.
I would avoid any mid that has resonances in the 3~5 kHz range - sure, these can be equalized, but after equalization, there are still noticeable colorations, particularly in comparison to a ribbon tweeter. When drivers break up, strange things happen to dispersion (thanks to multiple emission surfaces on the cone that go out of phase with each other), and equalization cannot correct for dispersion anomalies.
It's easy to be hypnotized by the power of digital equalization, but it doesn't magically make drivers flat, despite the measurements (at one point in space). Move the microphone around, or check the distortion spectra, and you'll find the resonances are still causing trouble - it's just been shuffled around to another domain that isn't as easy to measure. Try and choose a midrange that is a good complement to the RAAL - flat response, with very fast decay characteristics, and not requiring a notch filter in the passband or above the passband. Very few mids meet that criteria.
As you may have noticed, many commercial high-end systems with ribbon tweeters have poor subjective integration between the ribbon driver and bass/mid driver. Following these guidelines will save you a lot of expensive mistakes.
............. do yourself a favor and select a midrange that needs as little equalization as possible through 5 kHz, or above.
Completely agreed. That's why I suggested the Yamaha beryllium midrange dome, which works flawlessly from 500Hz - 6kHz (2nd order filtered) in the NS1000. Here we have the "presence" range handled by a single driver. I have no experience with Skaanings drivers but other drivers of the cone variety meeting the criteria will be very hard, maybe impossible to find.
Hi Lynn,
Thank you for your insightful comments.
Yes, I agree the Audio Technology drivers are quite amazing and the fact that you more or less can have them custom built for your application is quite unique for us DIY:ers. Actually ScanSpeak and AT drivers where almost the only two options I had for this project besides the Accuton drivers. I gave up the Accuton:s because of their hard cones and for the cone break-up reasons you mention below. I’m not the greatest fan of hard cone drivers, woofers and tweeter domes, even though there are examples of nice ones.![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Yes, unfortunately they are a bit more expensive than the Scans.
Yes, I fully agree and that’s why I have chosen the ScanSpeak 15W/15M as the midrange for this project. Besides that it sounds absolutely wonderful it measures like a dream without any visible cone break-ups and it has one of the smoothest roll-offs I’ve measured. Picture 1 & 2 shows my measurements of the ScanSpeak 15W/4531G00 on an 8.5” baffle. I think these Scans could be one of the few drivers that has a chance to marry well with the RAAL:s.
Picture 1: No smoothing , Tweeter-axis, Blue=0deg, Red=15deg, Green=30deg.
Picture 2: No smoothing , Tweeter-axis, Blue=0deg, Red=30deg, Green=45deg.
I’ve used Fountek ribbons in several designs without any problem, but they do need steep filters e.g. LR4 acoustical slopes and not lower than 3-3.5kHz without distortion becomes an issue. My research so far on the bigger RAAL indicates that it could be crossed somewhere between 2.5-3.5kHz without any distortion issues. I’ve seen that ShinOBIWAN on this forum has used the RAALS extensively. I must contact him and see if his willing to share some frequency and distortion measurements.
Yes, I agree there are many things to consider even when going active in the digital domain e.g. cone break-up, baffle step, baffle diffraction and off-axis dispersion etc. I have done a small study in this forum http://www.diyaudio.com/forums/mult...eqx-system-loudspeaker-measurement-study.html on this topic, using my DEQX.
Yes I agree![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
/Goran
Yes I agree
/Goran
Hi seebert,
It's an interesting idea, but it sounds both expensive and challenging to do. Do you have any suggestion on material choice?
Regard
/Goran
Have you had a look at the Factum here?
Strassacker: Lautsprecher - Boxen - Selbstbau
You can find the details under "Speaker Kits" then "Brands" then "ScanSpeak"
You may have set your heart on the RAAL, or you may want to go down the self-design route. This however would be much more straightforward with a guranteed result in a fraction of the time.
Also: Troel's Jensen 1071? Jensen-
You could check out the Focal build called Triga Neo Pro.
Triga Neo Pro
or the Trinity:
LSV Dieter Achenbach
One of the best (if not THE best) speakers I ever heard. Just to add other options.
Triga Neo Pro
or the Trinity:
Hi dublin78,
The RAAL isn’t written in stone yet for my design. I’m still doing research about it and the price for it must be taken into account.
It was a very long time ago I built someone else’s design. For me that would be like taking away about 99% of the fun. One exception is the Zaph SR71 loudspeaker which I have as a reference and used to benchmark my own design against, just to get a sanity check of the builds
The SR71 is slightly modified with added internal volume and a lower tuning, since in my opinion the original design is way too small in volume, at least in my listening room.
Other people’s designs inspire me, but I’m quite convinced that I will manage to produce a design by my own that I will enjoy![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
/Goran
I had actually missed that one. Thank you! I had to dig up my Hobby & Hifi magazine 4/2007 issue and yes, it looks like a nice design and somewhat similar to what I want to achieve, even in enclosure design.Have you had a look at the Factum here?
/Goran
Hi otter17,
Yes, I like Fountek ribbons and the Neo Pro 5i is certainly a viable option.
PHL drivers have caught my interest before and they are certainly a viable option if I’m going to build a high sensitivity design. On the downside from what I’ve seen on the frequency measurements of the PHL midwoofers, they doesn’t measure that great and will require some work to sing. I could be wrong about them since I haven’t heard any PHL:s and I’ve seen many people that like them a lot.
/Goran
/Goran
I couldn’t agree morethat’s why I love the sound from the smaller Revelator drivers and wants to build something around them. Unfortunately haven’t heard any from Illuminator series and if they are an improvement over the Revelators.
I've tried the 15w from the illuminator range and I have to say I wasn't impressed. It had a dark quality(veiled?) and I'm not the only one who thinks this, David Gatti too experienced a similar thing. Apparently the 12m is a much better mid for a three way. As for the revelators, they are great drivers and I'd consider them the best price/performance ratio out there if your aiming for high end. For me though if you throw the idea of price out the window then I find it hard to beat the Audio technology drivers, especially in the midrange. Look to their dedicated midrange units with optimised surround and I can't imagine anyone would be disappointed when paired with the RAAL 140-15.
Just to throw a wrench in things for you and because its around the same price as the 140-15d you might want to look at the Scanspeak D30 Beryllium. I agonised over this driver and the 140-15 for a long time and having compared the two in my own system I found it almost impossible to choose. The best way I can describe the differences is to play a very complex piece of music vs. a simple one. The D30 Be sounded cleaner on the complex and the 140-15 had more realism on the simple. The difference were small but and that was only thing I could definitively zero in on. Both are very good drivers. Eventually I stuck with the 140-15 in my system but the reason wasn't because it was superior but rather the two drivers were so alike that I decided it wasn't work the effort to rebuild the tweeter enclosure for the D30 Be.
Great info ShinOBIWAN. Exactly what I was looking for. Soon I will be posting my new alternatives based on the last couple of days research.
Thanks!
/Goran
Hi Shinobiwan,
When I look at the specifications of the Audio-technologie drivers I can not find superior figures. A much cheaper SB-acoustics would be the same thing to me. Where is your judgement based on is it the listening experience, or something else.
I am not against expensive capacitors and other hard to explain upgrades like expensive drivers, but I would like to get a grip on it how to judge them.
Hi Shinobiwan,
I've no experience with SBA drivers so maybe your right. Despite recent advances in loudspeaker design no one has been able 'hear' how a design would sound without listening to it first. So its even less likely that data sheets and measurements of a driver are going to tell you how a loudspeaker sounds when said driver is used as a part of it.
I can't see how you can say that you'd find the SBA to be the same thing as the AT without having investigated both drivers thoroughly within a design first and even then the opinion would only be valid for that design. Oh and since audio is quite subjective then the next guy could completely disagree.
I don't want to turn Gorans thread into yet another debate about driver cost vs. performance. Its diminishing returns when your talking $200+ for a driver and to be perfectly honest, the system design is far more important than an arbitrary performance indicator of a single component such as a driver but, everything being equal, using good drivers does lift the performance potential. Its hard to isolate and recommend individual elements a lot of the time when we're talking about someone else's design but in this case Goran has a somewhat similar setup to my own with the DEQX crossover and his interest in using the RAAL 140-15 which is a driver that I too use so it was natural for me to recommend the AT since I have very positive experiences with them.
AT also allow customisation of the TS to allow you to design your driver around your goals. That's something that's almost unique when talking about a single quantity order.
Objectively the AT drivers are not all the same. Just looking over the measured data from Zaph and Troels highlights this.
Subjectively on the few designs I've heard that use them (poly).. they sort of have a creamy yet clear quality to them without being over-damped - all of which is generally contradictory. Very "analog" like, yet not so transparent as ceramic or Al foil (..nor lower mass exotics). Basically rise times seem a little slow, but decay times are good with good depth (..from a suspension that is good at not only low spls, but also higher spl's).
It's also interesting to "tap" on them, without the amps being on, and listen to the signature of the diaphragm. More like "tapping" on metal driver than poly driver - even a traditional mineral loaded poly driver. Of course they also accommodate other diaphragms as well - even of your own manufacture.
- Super High-End 3-way floor-stander
