There is thread for more informations about HV23
http://www.diyaudio.com/forums/solid-state/162043-mosfet-amplifier-irfp240-irfp9240-71.html
thanks...
Dear Sir,
I have completed the SR200 amp and it is working. But when I am connecting drivers with RCA cables hum noise is noticed if i put my ears close to speakers.
Please advise what I need to DO to stop the hum noise.
Samrat
Can you post your ground wireing circuit? Is there hum and noise with shorted input to gnd.
Have you measured the voltage and from there calculated the current through these 5 resistors?
Post1 shows 2k2 and 6k8
The 2k2 will have ~26Vdc across each.
The 6k8 will have ~120Vdc across it.
The powers dissipated will be ~300mW and 2100mW
No wonder they are running hot !
Current thru 6k8 is 10mA power dissipate will be 680mW
Apex is confirming that the cascode transistor is absorbing approximately half of the voltage drop.Thanks for your help andrew
I am using R24- 10k 2 watts not 6k8 is there any problem?
Measure your circuit and post the results.
Across R24- 10k 2watts its 73volts
The powers dissipate is about 500mW, 2watts resistor is ok and must be hot
Apex sir any voltages to be measured to conform amp is ok
Hello apex sir please help me
Voltage on zeners must be 15V, on resistors R16, R17 about 1,5V and on R27, R28 about 1V.
What are voltages to be there across R7,8,9,10 and R24
This voltages isn't important.
Voltages on zeners 15.87V , on resistors R16,R17 - 1.6V and on R27,R28 - .98V
powered with 65-0-65VDC, what do you say Mr.apex
- Studio Reference Amplifier
