Studio Reference Amplifier
my work, sr200 with 1 pair transistors was supplied by 40vac 5 ampere transformer. Sound had nice bass and mid.
Sir apex, What is the rating watt for 10 ohm resistor between signal ground and ground (1/4 or 1/2 or 1 or 2 watt) ? What is the rating watt for 220 ohm resistor between emitor 2sc4793 and emitor 2sa1837 (1/4 or 1/2 or 1 or 2 watt) ? What is the rating for coil (1uH or 2uH or 10uH, or etc) ? Thank you very much.
U can use 1W resistors and 4uH coil (post #43)
Driver TR?
Hi Apex,
I will try to make new PCB design for SR200, it hard I guess 😉
I want to ask it is ok if I separate driver A1837/C4793 from main heatsink?
so the PCB is not so big 🙂
I saw your SR400 component side, there is only VBE multiplier (BD139) on main heatsink...
Also can replace A1837/C4793(out of stock here) with A968/C2238(I have some)?
Hi Apex,
You can use A968/C2238 on separate heatsink, output stage of SR400 is TEF, MJE340/350 are predrivers on separate heasinks, and one pair A1493/C5200 is drivers on main heatsink with outputs.
