SSLV1.1 builds & fairy tales
What make is the big filter 6800uF PSU cap?
It is branded "Marcon"
When I remember correctly, I unsoldered it out of an never used Studer smps.
I think for the first fire up, I will use a reduced voltage (not 36VAC) from this test-tranny (the device on the left), to not exceed the limits of some parts.
Franz
It has a 32VAC configuration too I see. Practical thing. Not a variac, multitap. Fully isolated? Not autoformer?
Indeed, a very practical thing.
Yes, it is fully isolated, not an autoformer. It is a "normal" 230V primary tranny inside with two double tapped 16VAC secondaries.
I purchased it on a flea market, some time ago.
Franz
Hmmm
[sarcasm on]
Tomorrow, we in Switzerland are looking how things are developping in the world.
[sarcasm off]
I for myself I will spend the day drilling, soldering and testing...
Franz
/Edit
Imagine having a Swiss bank holiday. Luxury only to put the phrase together.
Oh, it IS a bank holiday. National holiday.
Hi Erik
I purchased this caps in a small shop in Zurich, where the stock is empty now.
About the quality: this are good caps.
And they look good on a black pcb.
I did not compare it to others but I also use some in my simplistic Salas RIAA and I like the result.
I dont understand, why they brand this caps as MKP.
This caps are made of metallized polycarbonate, I would call it MKC.
Datasheet:
http://www.lcap.ch/pagesGB/textesGB/fichiersPdf/precision/MKP_g.pdf
Franz
diyAudio Chief Moderator
Joined 2002
Threading on a sunny day was enough to call it a day. Looks good.
Joined 2002
Hi Erik
Datasheet:
Franz
Maybe they had tons of printed boxes from their MKP ranges to use?
There is a thread running about MKC and its qualities in audio as we speak...
