I did this concertina splitting with a LND150 small MOSFET about a year ago:
http://www.diyaudio.com/forums/tubes-valves/213947-just-what-world-needs-another-el84-amp.html
It works just fine and has been in use for a year with no issue. It makes life so simple I don't know why more people don't do it.
cool...thanks
there are surely better posts to quote from your thread... but I just couldn't resist this one ...😀 (I hope George won't mind)
I'm sure that this will rattle the purists.........In many guitar amp circuits, just stick it into the 12AX7 sockets.....it works.
wow...a search on LND150 reveals quite a lot of schematics
and a look at spec sheet reveals lowest capacitance...7.5/2.5/0.5
but a very low current rating of max 3ma
doesn't sound like giving much room for errors ?
The PNP .model I used has CJC=150pF of Miller.
I figure from base to collector looks like 2x gain?
And 12AX7 plate resistance into CCS is 62.5K
Gives a corner at 16,985Hz.
This is too low even to be the dominant pole...
LTSpice knew CJC. I wonder why it didn't show
more damage from Miller in the overall results?
If we want 100KHz open loop, we want <25pF
here, or maybe a cascode of some sort...
I picked a rather big transistor, just cause I
wanted the TO220 thermal package, I might
need to re-think that decision...
Yeah I could definately go with that one. Though I would
wish to trade-in that 450V spec for some more gm or a
higher Wattage. 1.55mA*450V=700mW. Voltage spec is
perhaps overkill, not so useful at a realistic current. But
there may be reason to stand-off that much voltage at
no current.
Its weakest spec is 40mS, only 30x more gm than 12AX7.
Still, ain't nothing in AB1 you couldn't drive with that.
Or perhaps that capacitance is measured with 25V on the
drain, and no mention how that cap might squirm if you
swing below 25V bias? Triodes can't go there anyway...
no current.
The wimpiest of small signal tubes can drive the ZVx0545A MOSFETs, with great aplomb.
For the really difficult situations, consider cascading FETs. Cap. couple the "little fellers" into big, "honking", TO220 case parts. Small value, highly transparent, film parts are practical as couplers, given the extraordinarily high I/P impedance of the 2nd MOSFET.
Driving the ZVx0545A isn't the problem. But 700mW might be a problem
driving finals. It simply can't conduct enough current (without exceeding
wattage) to properly shame a triode splitter...
Can we find a discrete P in TO128 or TO220 thats HV and <25pf Miller?
In through hole package that might exceed plate dissipation of an AX7?
How bout this TO220 at a dollarseventeen?
http://www.fairchildsemi.com/ds/FQ/FQP3P50.pdf
Or this TO126 at fourtysixcents?
http://www.fairchildsemi.com/ds/KS/KSA1381.pdf
P Channel parts in high voltage are thin on the ground. Try Fairchild, ST and Alpha Omega, though I doubt you'll find anything close to the 25pF gate capacitance you're seeking. 15 years or so ago, Supertex used to offer their small-die parts in TO-220 packages, but no more (and those clocked in at ~50 pF). If you really want the small capacitance with some dissipation capability, the best option is to take one of the Zetex/Diodes, Inc. E-line parts and glue on a heat sink. Good luck.
I don't mind gate to source, or base to emitter cap, those are followers...
Its only the Miller end, swinging the opposite direction, I worry not more
than 25pF for this application.
The best option right now for a P-channel part would appear to be a Zetex or Supertex part in a SOT-223 package, which can use PCB copper for a heat sink, or can be jiggered up with a piece of copper foil soldered to the tab. The Fairchild FPQ1P50 would have been perfect, but it's no longer made, though you might find some old stock parts if you're lucky. For some reason, both Fairchild and ST chopped a lot of the smallest parts out of their lineup. For an N-Channel driver, the Alpha Omega part still looks like the best bet for a TO-220 devce, and it's cheap to boot.
regarding TO-92
if you drill a matching hole in thick solid aluminium
and put the TO-92 in with 'goo', would give any cooling ?
Maybe some - it would have to be a really tight fit. You'd be better off glueing a heat sink to one of the Zetex E-line parts, which look like a TO-92 that's been flattened out. Using one of the TO-92 heat sinks referenced by Eli with some loaded epoxy like Arctic silver would work. Keep in mind that heat sinks designed for TO-92 won't work with the E-line parts, as the shape is different.
The AO part you mention is N-Channel...
Not a "bad" thing, but prohibits some
of the neat tricks you can pull with P.
... it would have to be a really tight fit....
if needed, press fit would not be any problem
I can do some mechanical proto experiments later if it goes that way
If you use the Zetex parts, they come in an E-line (read flat) package, so press fit won't work, especially with a round hole. The conventional TO-92 parts will be limited by the junction to case thermal resistance of a conventional TO-92 lead frame and package, which is pretty high. I woouldn't try wringing more than about a watt out of a conventional TO-92, even with help. The normal limit for an unaided TO-92 packake in free air would be about 150-200mW, depending on the temperature rise you're willing to accept.
The more I look at this spec sheet, the better I like it...
Details even capacitance squirm vs Volts on collector
in a very clean and legible graph. How often you get
the whole story like that?
- Tubes / Valves
- SS phase splitters?
