Remove the bridge.
What's the DC voltage across terminals 1 and 2 before the end of the mute delay?
When power on, start from 0.09v and go to 1.16v (muting off)
Parallel a capacitor (about 100uF) across terminals 1 and 2. Does that stop the bad channels from popping?
Remove the bridge.
I have checked the voltage across pin 1-2 of the optocoupler better, i have -0.9V when is power off, when power on start up to 1.16V.
I have tryed with 100uf but no result, it's the same
C45 may be part of the delay on.
Is the voltage across this cap (just before applying remote voltage) the same when the amp pops and when it powers up quietly?
Yes, it's the same
I have tried with 10k resistor on optocoupler pin 1-2, the voltage, when i leave remote in, go to 0v fastly, but the pop is still present..
Does Q9 drive the opto-coupler via the 1k 1/2w resistor?
If so, pull it and see if the pop is gone.
Yes, q9 is optocoupler driver. Without Q9 i have the same pop
Did you try lifting terminals 1 and 2 to disable the opto-coupler or did you only try shorting them?
If you rub the tip of your scope (on DC coupling, 1v/div, 2ms/div) probe around in the area of the optocoupler (both sides of the board), does the trace ever deflect from the reference.
I have only shorted pin 1-2
Did your scope have any deflection when checking for leakage as suggested?
No deflection 🙁
Confirm that you had absolutely no pop on any channel, no matter what with terminals 1 and 2 shorted?
Lift 1 and 2 and retest for noise.
Optocoupler pin 1-2 shorted= no pop
Optocoupler pin 1-2 lifted= pop present
That makes no sense, to me. Do you have another optocoupler that you could install?
Yes i think, i must check datasheet, let you know
I have tried with another optocoupler, no difference 🙁
- General Interest
- Car Audio
- Soundstream lil wonder 5.1000 power-on bump
