So no endless '1000 pieces available' source anymore....
Acronman was the real last available reliable resource in the world 🙁
Gone is my dream of building a half '40 years commemorative VFET Amp'. 🙁😡
At least I hope that I prevent others to buy from this resource.
aaah crap.
I better find the ones I purchased then (somewhere still hiding in the garage)
Teabag,
Will you be arranging for production and taking orders for these "AL" PCBs anytime soon?
I'm definitely interested in buying at least 4 pairs.
Thank you for your considerable efforts in designing them.
Msr. Mojo
haha, silly name for an Amplifier: 'Al'
Better call it V-Al-FET or VAlFET 😀
aaah crap.
If you happen to find a lot, I'll buy them from you 😛
I don't recall buying many (they weren't the cheapest devices) but if I have more than 2 of each. I'll be happy to sell the excess.If you happen to find a lot, I'll buy them from you 😛
Thank you Walter for taking the time to post this - it's a real service to our forum ...
Yes, If walter wanna build the 40th anniversary with the 2sk60/j18 with 20 watt of dissipation. Is a follower. Use IRFP.
Don't know what you both mean, but this is what I want to build, see picture.
I see it's not a half 40th anniversary but only a third 😀 (with 2 matched VFETS instead of the 6 Nelson used).
So I need 4 pairs of matched 2SK82 and four pairs of matched 2SJ28 for a stereo amp.
I have already 3 reasonably matched pairs of 2SJ28, but these can still be bought by Acronman, so the fourth pair will be possible.
And I had two pairs of 2SK82, and luckily the one and only real 2SK82 of the ten pieces I bought, matches nicely with a 2SK82 I already had🙂🙂
So I now also have three matched pairs of 2SK82.
I only need one extra pair, or even one extra 2SK82 which matches with the VFET's I already have. So if someone has a 2SK82 which matches one of these, you can make me a happy man🙂 :
you're big boy .... knowing that - as long you're keeping them in sane dissipation level , everything will be fine
I have no luck again....😡
Bought 10 pieces (and get some discount) 2SK82 of the ALiExpress Eternal Hong:
Sorry to hear that Walter, i hope you get a refund.
Dear, you are wasting a lot of vfet in a source follower, anything you use is the same. The key is the symmetry of all the front end. The rest is almost transparent. If you got 2sk60/j28 in enough quantity you have the amp. The dissipation is not much.
Tea-Bag: what does the mechanical hardware stack up look like which prevents the top copper on the outer TO-3 pads from shorting against the mounting flange?
Like in the case of WalterW, I too got 4 pieces of 2SK82 from EternalHong on Aliexpress. The printing is distinctly different from the ones I got from Singapore and is also printed upside down from a pin orientation perspective. I am fairly certain that they are not the genuine Sony VFETs.
Cheers.
Cheers.
Did some measurements of the VFETS I have using NP's suggested method in this thread. As suggested by him, I measured VGS for 0.5V across 1 Ohm resistor on the drain pin. I think I have few near matches, but not close. Can members kindly comment if any of the pairs is a viable pair in the VFET2 circuit?
I will hazard a guess that some of the gurus on this forum can make them behave similar by altering the VGS closer to the other matched DUT at a required current rating like 1A, but it is way beyond my capability.
2SK82 (VGS)
Pair 1: 7.52V and 7.81V
Pair 2: 8.96V and 8.76V
Pair 3: 7.92V and 8.25V
2SJ28 (VGS):
Pair 1: 10.64V, 10.66V
Pair 2: 6.61V, 6.66V
Pair 3: 8.79V, 8.51V
Pair 4: 6.91V, 7.05V
2SK82 (VGS)
2SJ28 (VGS):
2SJ28 (VGS):
I would pair the 7.81V 2SK82 (from pair 1) with the 7.92V (from pair 3), then with pair 2 also you have 2 matched 2SK82 pairs that are within 0.2V. Your pair 1 and 2 of 2SJ28 are very nice.
So you're in business to build a part 2 with 2 pairs per channel 🙂
- Sony vFET Amplifier Part 2
