Hi all,
I've got a PSU question. Got all the parts and will be using the DIYAUDIO PSU with an Antek 400 VA trafo with dual secondaries. Is it better to set the PSU up as dual mono by not connecting the grounds of the two sides, or doesn't it make much difference.
Paul
Paul
One transformer with dual secondaries makes one bipolar (+V/GND/-V) power supply. You've got to tie the Grounds on the PSU board in order to define ground.
If you want dual mono you'll need 2 transformers, 2 PSU boards, and wire each channel to its own dedicated PSU. At that point it makes good sense to just make monoblocks. 😀
Single supply it is. Thanks for clearing this up Jim.
Paul
Received my boards and an email that my opportunity to buy is coming up. Looking like I will be building one of these nice amps.
Russellc
Russellc
Hi. Just bought the official VFET kit on diyaudio store. Thanks guys for putting together such nice kit.
I know there was a few versions of the schematic around. Where can I find the schematic & BOM that match the kit sold in store?
SB
SB
Are there anyone else from Denmark which is purchasing this kit and would like to share shipping cost, please get in touch with me!
SB
http://www.firstwatt.com/pdf/art_diy_sony_vfet.pdf
Thanks for the link. I have in stock this transfo, will it do, it is slightly smaller than the dual 22V, 300VA Antek transfo recommended?
Y236661 Dual 18V, 6.94A Sec, 250VA, Avel Lindberg
SB
SB
SB
I would not use it. Too good a design to compromise.
Have you two of these?
Voltages and VAs are a little bit lower than as I would like.
You can expect secondary voltages somewhat below 24VDC.
But if you will follow the description, there can't be a big mistake:
"NOTES ON SUPPLY VOLTAGES NOT +/-28V
This amplifier is designed to operate with voltages between about +/-26V DC
and +/-30V DC.
If your supply is lower than this, you should adjust R15 and R16 down so that
the R19 and R20 have at least 2 volts across them.
For example, if the supplies are +/-24V as measured at T6 and T8 (relative to
ground) then the regulators Q13 and Q14 need to be set for 2 volts below that at
22V each.
To compute the new value of R15 and R16:
22V = 2.5V * (R15+4750 ohms)/4750 ohms
22V *4750 ohms / 2.5V = R15 +4750 ohms
41800 ohms = R15 + 4750 ohms
R15 = 37050 ohms.
You would pick the closest 1% resistor, which would be 36K or 36.5K for R15
and R16.
Other parts of the circuit are not very sensitive to supply values. Practically speaking, you should not try to make this amplifier with rail voltages below 20 volts, and above 32 volts."
and +/-30V DC.
22V each.
R15 = 37050 ohms.
and R16.
I have about 6-700VA trannies with 4x24VAC secondaries.
It gives me +-30VDC supply voltages.
I feel, it is better than what you can expect with your tranny.
If you want to build independent PSUs for each channel, use two units of model 057015201.
https://shop.plitron.com/shopexd.asp?id=121
If you plan on using a single PSU, the model is 077015201.
https://shop.plitron.com/shopexd.asp?id=164
[emoji15]$$$
I'll stick with Antek.
Sent from my iPhone using Tapatalk
Something is really odd with the sizes specified for those 160VA transformers. I somehow doubt that it is 250mm wide in diameter, seeing that my Amplimo 18V 650VA transformer is 140mm wide.
EDIT: I checked the spec sheet PDF, and it is indeed 110mm wide, so their web page for the product is in error. Probably another cut-and-past developer error.
2nd EDIT: Just picked up my kit from the PO. Now I just need the transformers and chassis.
You shouldn't use the outer diameter alone to compare transformers. Pay attention also to the inner diameter (the doughnut hole) and, of course, the height.
Several years ago when other members started talking about Antek transformers, I was initially skeptical. I tried one and was satisfied with the results, so it became my transformer of choice. The exception was my Aleph J build in 2013. Antek had lost most of its stock to a fire earlier that year, so I decided to source the transformers elsewhere and purchased Avel Lindberg from Parts Express.
Some may be asking: Why not Plitron? Even though it is clearly better built than the Antek, when taking into account the initial cost, shipping costs and, worst of all, brokerage fees, I can't justify paying almost three times for a transformer that IS NOT three times better. My reply to WBS was not an endorsement, as I have not purchased from Plitron in a while.
- Sony vFET Amplifier Part 2
