Something to lighten the mood
Galu, I agree with your approach.
It should get to the left bottom red part area.
The trouble is, you need the area of a segment which is a messy calculation because of its ugly angle.
I did the same approach in the upper right to get the upper right red area. I fell on the very same segment calculation.
In post #1139 I show how I get at the upper right red part. There I comment about the ugliness of the segment area calculation.
In post #1140 I give a numerical answer.
Find the area in red.
21.46... not bad, Galu. 🙂
I got 21.46018366 to 10 digits.
Alas the page is too small for the exact answer. 😀
To get the red bottom right area, all you have to do is work out the area of a quarter of a circle then subtract it from the area of a square drawn on its radius as shown in the attached diagram.
Area of circle quadrant = (3.142 x r^2)/4 = (3.142 x 10^2)/4 = 78.55
Area of square = r^2 = 10^2 = 100
So the difference in area = (100 - 78.55) = 21.45
Yes, and I congratulated you on your answer! 😎
Your approach will agree with the contents of this link: Circle Sector and Segment
It shows how to get the area of the segment by subracting the triangular area enclosed by two radii separated by an angle θ.
Calculating θ is the problem!
Indeed, the fun is in the method of finding the answer.
Meanwhile, with Galu's methode, I calculated the area of the left bottom red area.
So I have the two hard to get areas of the small red parts.
I do not publish them to not spoil the fun.
A very accurate one for the lower left red area.
A crude value I gave in #1180 for the upper right red area.
I am pretty confident calculations are right because their sum is as expected.
Have fun and get them with many digits.
TBH, mcchambin, I didn't really follow your method.
Cal's original problem was easy enough. Calculate the area in Red:
990319d1634223624-lighten-mood-squaring-circle-jpg
25 (4 - Pi) or 100 - 25Pi. 21.46018366...
Your segment problem was quite intractable to my most cunning methods. I suspect there is no algebraic solution. Only approximate numerical methods.
I found myself trying to solve 4 variables with 3 equations.
I think this has no exact answer algebraically. Just like the arc length or circumference of the Ellipse. You can only look it up in tables;
Elliptic integral - Wikipedia
A chap walks into the optometrists carrying a suitcase.
He opens it to reveal the largest turd imaginable.
Shocked, the optometrist says, "Take that the heck out of here. It's a doctor you need, not an optometrist!"
The chap retorts, "I do need an optometrist. You see, every time I do one of these my eyes water."
This chap walked into Tesco tonight. Picked up a loaf of bread, 4 litres of milk and 4 tins of Beer. Customer Assistant Operative suggested a Plastic carrier bag...
The chap instantly declined, wishing to save the Turtles and keep in with GretaThunberg. Nothing he couldn't carry he thought. 🙂
How wrong he was. The ecologically friendly cardboard wrapper almost instantly collapsed, spewing beer tins onto the pavement (er, sidewalk for the cousins...). What was wrong with those plastic rings? Could it get worse? Yes, the ecologically economical flimsy thin tins immediately ruptured with a hissing noise,
Either it went to waste, or I had to drink it immediately. Well, it's an ill-wind that blows nobody any good. Hic. 😱
There are two trigonometric functions involved.
arctan() and sin()
No big deal.
Just my 2 cents:
Subtract the area of one circle from the area of half-rectangle and you are done. Results in 21.46018366
