Old measurements updated with IMD and the voice coil HD distortion data:
ScanSpeak 12MU/4731T00 | HiFiCompass
Wavecor WF120BD03 | HiFiCompass
Dayton Audio RS125P-4 | HiFiCompass
SB Acoustics SB17CRC35-8 | HiFiCompass
SB Acoustics SB17NBAC35-8 | HiFiCompass
Accuton AS168-9-470 | HiFiCompass
Accuton C168-6-990 CELL | HiFiCompass
Those IMD and voice coil HD data are a really nice addition to your measurements
Those examples confirm that, while they are excellent midrange, the SB17NBAC and CRC really don't like excursion (also measured in Erin's Klippel test, 2.8mm Klippel verified). Which explains why some people thought that the Satori family sounded better in two way speakers, despite somewhat inferior midrange 2nd HD performance.
Vifa NE180W-04 | HiFiCompass
Wavecor WF182BD03 | HiFiCompass
Morel TSCM634 | HiFiCompass
Compared to similar sized vifa and wavecor and accuton the imd for sb17nac looks rather good, but maybe i read the graphs in the wrong way
Those NAC's are among the better speakers out there for midrange duty, besides Purifi's drivers. Thanks for adding the IMD data.
Yeah IMD is great is long as excursion is low. The Illuminator isn't so impressive given the cost. Wavecor looks well balanced. And the Dayton is damn good considering the price!
If limited to bass and low-mid duty, the WO24P is also excellent, and for a reasonable price compared to the rest of the Satori family (around 200€ per unit tax included in Europe). No quite the same category of drivers of course, but it beats the Purifi as far as IMD is concerned.
Interesting observation. It looks like the WO24 is a well made driver, really well made. Comparing it to the MW19 (7"), the WO24 has less distortion overall which indicates better linearity and better suspension. The WO24 is easily workable.If limited to bass and low-mid duty, the WO24P is also excellent, and for a reasonable price compared to the rest of the Satori family (around 200€ per unit tax included in Europe). No quite the same category of drivers of course, but it beats the Purifi as far as IMD is concerned.
Looking forward to the IMD value of the NRX line.
The waterfall plot of the W024-p looks quite busy. Should this be of a concern? The MW16-P looks comparatively very nice. I'm really not sure what to make of some of this data.
@hificompass - any chance you will be getting the new(ish) SB29NRX75-8 (8 ohm) in for a test any time soon.
Looks an interesting speaker - almost identical box requirements and headline performance as the WO24P-4 (possibly easier to xover as less break up) but with a bigger area (312sq.cm vs 255sq.cm) and a bit more head room (xmax) but slightly heavier cone. Interesting to see if the distortion can compare to the WO24P-4 and also a subjective comparison.
The waterfall is directly linked to the frequency response of the driver. The WO24 has quite violent cone break-up peaks between 3khz and 5khz (the cone seems to be quite rigid). Those translate as resonances in the time domain. Same thing on most metal or hard cone/dome drivers. Below that it should be clean, since there is no accident on the FR.
But personally I would not really use the WO24 above 1khz or even 600hz. The 3rd and 5th order HD are already strong there because of the cone break-up peaks. The MW16-P is much more suitable as a midrange driver. But between 80hz and 600hz, the WO24 is a beast (at least as far as measurements are concerned).
..But between 80hz and 600hz, the WO24 is a beast (at least as far as measurements are concerned).
That's promising, since that just about perfectly covers the absolute widest range I would need from it!
I rather like this comparison:
Grand Comparatif de 10 pouces Partie 2 - JustDIYIt !
The “best” is rather complex.
I think, there is no chance in the nearest some months.@hificompass - any chance you will be getting the new(ish) SB29NRX75-8 (8 ohm) in for a test any time soon.
If that woofer is just 8-ohm version of the SB29NRX75-6, I don't recommend it. Not the best measurements and sound, this woofer is far from WO24P
Yes, you are quite right, SB17NBAC looks very good🙂Compared to similar sized vifa and wavecor and accuton the imd for sb17nac looks rather good, but maybe i read the graphs in the wrong way
They are the same as for the CRC and NBAC lines
Thx, I will need to build a 4-way with WO24, SB15NBAC, SB17MFC and T25B-6They are the same as for the CRC and NBAC lines
Interesting but don't you think the SB17MFC and SB15NBAC are kind of redundant ?
A bit off topic, but I also had some idea/fantasy (far beyond what I can actually build and afford
It would be in a extended d'appolito configuration (SSWMTMW) in order to reduce unwanted vertical reflections from the desk and ground, as well as increasing power handling. Narrow vertical directivity would not be a problem since I only listen while sitting.
- 2 Sealed Ultimax 15" or something similar below 80-100Hz
- 2 WO24 between 80/100hz and 400/500hz
- 2 SB15NBAC between 400/500hz and 3khz
- 1 T25B, preferably in an Augerpro waveguide, above 3khz
Realistically never going to happen though... 😀
That is very.... not optimal driver combo. First the sizes of drivers, second each driver has different cone material.
WO24 + MW16TX + T25 in Augerpro WG would be much reasonable and with potential for a good sound.
- Some speaker driver measurements...
